Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 181 to 195 of 200
Thread: SkyActiv Oil Analysis Thread
  1. #181
    Registered Member RepeatMazda's Avatar
    '16.5 CX-5 Touring AWD
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    Quote Originally Posted by cz5gt View Post
    first oil change cx5 2.5NA. mazda oil w/ moly 0w20 from factory. 2724 miles on the car.
    Pretty typical for the break-in period. Thanks for sharing.
    • 2016.5 CX-5 Touring AWD
    • 2018 Alfa Romeo Giulia Ti Sport Q4
  2. #182
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    Here's my 6th and final UOA. This winter was a brutally cold one for us. I think the colder temps, combined with higher idle times, more stop/go and short trips is what caused the increase in Iron. Typically we don't idle as much and we take longer weekend trips, we've cut down considerably on these trips which is what has kept the mileage down. Also, just before changing, the wife went on a 6 mile trip which I think contributed to the fuel dilution as well. Unlike the other OCIs, this one didn't require a top off of any kind. Technically the others didn't require one either as I was only down 1/2 quart or less, but with Maxlife in the sump, I didn't lose any noticeable amount from the dipstick.
    0 - 1,169 - Factory Fill
    1,169 - 10,120 - Mag1 0w20
    10,120 - 19,949 - Mobil Super Syn 0w20
    19,949 - 30,031 - Mobil 1 EP 0w20
    30,031 - 39,486 - SynPower 0w20
    39,486 - 47,714 - SynPower 0w20
    47,714 - 54,782 - Synthetic MaxLife 0w20
    54,782 - Present - Citgo Supergard Synthetic 5w30
    6th UOA.pdf
  3. #183
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,823
    Looks pretty good to me. Ed
  4. #184
    Registered Member
    2019 CX-5 Reserve Eternal Blue
    Join Date
    Aug 2018
    Location
    Central Virginia, USA...the winding rural part
    Posts
    641
    Quote Originally Posted by RepeatMazda View Post
    6th UOA.pdf
    Looks like a little dilution issue at your 2/3/17 analysis (more so than your current one), with only Trace amounts in the analyses during the warmer months. I guess that makes sense, huh? Seems like evaluating oil performance needs to take seasonality into account, however one might adjust for that.
    Was the TBN your only option added to the Standard Test? Did you have an idea as to where TBN should have started out?
    I've never had this done, but in the age of GDI engines, I can see the value. It was the oil dilution issue that caused me to run away from Hondas and buy a Mazda. And reading stories on other sites, I see folks claim that they were able to take the report into dealers to have major warranty work done that might have otherwise gone unnoticed (trace antifreeze in the oil due to warped heads in one case).
    Interesting stuff...
  5. #185
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD Tech
    Join Date
    Oct 2017
    Location
    State of Jefferson - southern Oregon
    Posts
    2,046
    Handy idea: How to Quickly Open Oil Filters for inspection [<3m] for eyeball inspection.
  6. #186
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    Quote Originally Posted by Avoidin Deer View Post
    Yes, TBN is all I added to the analysis.
    According to PQIA, a SynPower VOA on 3/6/17 showed a virgin TBN of 8.88. SynPower isn't the exact same as the MaxLife variant I used, but is be quite similar so the TBN shouldn't be far off if at all.
  7. #187
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    641
    Interesting that the TBN looks consistently strong.
  8. #188
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    Ironically enough, PQIA just published new results yesterday. One of them was Valvoline Synthetic MaxLife, virgin TBN is 9.16. The formulation has changed a bit compared to what I used, but I think it's a safe bet that the virgin TBN of what I used was around 9.
  9. #189
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    641
    So much minutia to wade through in life.
    As I understand it, the "B" in TBN (Base) fights off the acids in the oil so as to preserve the oil's lubricating properties...it has no other function, and "too much" of it does no harm. So starting off with a higher number may or may not be of value, since all that is required is "enough" to neutralize the acid that's present.
    I find it interesting that the Base is consumed quickly, then levels off, and then decays slowly. Makes one wonder exactly what is going on in there...chemically speaking. I wonder if there's a consistent amount of Base consumed over running time, such that those oils with a higher starting number could be used longer before approaching a level of 1.
    Then you wonder how many of those metals are a byproduct of combustion, and how many are shards of motors.
  10. #190
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    What makes up the TBN is equally important as the TBN itself. Even 8 or so years ago you'd see some of the top tier synthetics pushing TBNs of 12. Now, they're almost always in the 8-10 range, typically on the lower end. As base oils improve and additive technology improves, I think we'll see a lower starting TBN because TBN retention is stronger.
  11. #191
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    641
    I wonder if that means a future like-kind decrease in Acceptable Minimums on the reports.
    This thread has caused me to go do some reading on the subject of oil analyses. Many articles claim that except for diagnosing a specific one-time issue, they provide no value (mostly because--like "the best fuel for my car"--we don't drive in repeatable controlled laboratory conditions.) But for what amounts to the cost of an extra couple of gallons of gas per month, there's lots of good info to be had in each discrete report as well as with the trends.
    For instance, I was looking at the correlation between Fuel%, Flashpoint and Viscosity (assuming they are all affected by Dilution). No conclusions, just looking at it and wondering if some oils might be less susceptible to dilution, or if the timing of topping off the oil affects it (1/2 quart soon before the next oil change could bump the numbers.)
    I also noticed that the Values Should Be column for properties only apply to the then-current sample. Have they changed for you from report to report? They're obviously not driven by past data/averages (no viscosity samples came anywhere near the high end of their "Should Be" ranges). And they are the same on your 55,000 mile report as they are on the 2,700 report CZ5GT posted.
  12. #192
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    I'm not entirely sold on this point. Most UOAs I've seen show a correlation between flashpoint and fuel dilution. For instance, here is a graph just from my experience. Trace results were given a value of 0.2.
  13. #193
    Registered Member
    2019 CX-5 GT AWD, eternal blue
    Join Date
    Apr 2019
    Location
    Folsom, CA
    Posts
    14
    The Zepro 0W20 oil with moly is now on sale on Amazon for $31
  14. #194
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    I looked into this and got some good information from Blackstone. While I don't agree with their methodology, they were open and honest about how they come up with these values. Essentially, they use information from the PDS for the particular oil being analyzed. More information and a small discussion can be found here.
  15. #195
    Registered Member
    Join Date
    Aug 2018
    Location
    Posts
    641
    Thanks for circling back.
    I just read that BITOG thread. Blackstone is open about their methodology, but as you and others point out, some of it makes no sense.
    In reading this stuff, I find lots of rabbit holes within which one might get lost. And my "Applies Only To The Current Sample" questions still hang out there.
    One would think things like Fuel%, Antifreeze% and Water% should have absolute thresholds, not changing ones. In fact, all of the "Applies Only To The Current Sample" ranges are identical on the analysis posted by Kedis82ZE8 in Comment #1 in this thread, the one posted by Triton46 in Comment #39 in this thread, and in the analysis you posted.
    So I went and looked at a December 2016 report posted by a guy for his Scion, and the viscosity "Applies Only To The Current Sample" ranges are different from the three CX-5 reports posted here. This somewhat supports the observation that these reference ranges are pulled from Blackstone's historical database of analyses from identical models (engines?).
    So maybe that's what they mean when they say "Applies Only To The Current Sample." Perhaps a more accurate statement might be "Specific To This Make & Model" (or maybe "Specific To This Engine", since everyone's model year is different) And if what I read is correct, it only tells you how you fare relative to similar vehicles/engines (pulled from their analysis database), as opposed to being a discrete standard. (And note that some BITOG folks point out that the PDS for oils lists a viscosity number, not the range that Blackstone cites).
    Here's how those "Values Should Be" for the CX-5 and the SCION compare:
    Same for the three CX-5s, Scion is different
    SUS Viscosity
    cST Viscosity
    Same for the three CX-5s and for the Scion
    Flashpoint
    Fuel%
    Antifreeze%
    Water%
    Insolubles%
    It seems as though Viscosity "Should Be" is the only value that varies by model and the others ARE universal discrete standards. Maybe.
    As I said, lots of rabbit holes.
Similar Threads
  1. Used oil analysis
    By Seminole in forum CX-5 Engine & Transmission
    Last Post: 04-24-2016, 09:49 AM
  2. My CX-5 UOA (Used Oil Analysis)
    By JTNY in forum CX-5 Engine & Transmission
    Last Post: 01-19-2014, 12:20 AM
  3. Replies: 20
    Last Post: 11-17-2012, 02:29 PM
  4. My Oil Analysis Results
    By Jasnall in forum Mazdaspeed3
    Last Post: 10-27-2009, 07:24 PM
  5. Oil analysis..who,what,where,when, and how?
    By Mike R in forum Mazda Protege
    Last Post: 04-24-2004, 01:35 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
