Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 166 to 180 of 200
Thread: SkyActiv Oil Analysis Thread
  1. #166
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,004
    Hey guys...I captured a sample of ATF from my first drain/fill session and wasn't sure if that analysis needed TBN or not?
  2. #167
    Registered Member RepeatMazda's Avatar
    '16.5 CX-5 Touring AWD
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    Quote Originally Posted by ColoradoDriver View Post
    According to Blackstone, TBN on ATF doesn't tell much. You can choose to include a TAN (Total Acid Number) if you'd like.
    • 2016.5 CX-5 Touring AWD
    • 2018 Alfa Romeo Giulia Ti Sport Q4
  3. #168
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,004
    Quote Originally Posted by RepeatMazda View Post
    Perfect, thank you!
  4. #169
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,004
    Just did another oil change. A little early at 6300 miles, but decided to do it as I just got back from a road trip and wanted to do it before it got to much colder.
    Been doing mostly city driving lately besides the road trip. I drained a little over 4 qts, so I guess I burned through 1 qt since the last change.....(I always add 5).
    I took another sample, but by mistake I maybe did not run the engine enough before collecting, so guess we'll see how bad that affects the sample.
  5. #170
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,700
    Since the warranty it's over, I change it at 10k. At 7.5k, I add another fresh bottle, because it needs it. Costco, or Sam's Club sell a six bottle package (Mobil One 0w20) for around $26.
  6. #171
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,779
    Arrow SkyActiv Oil Analysis Thread
    Quote Originally Posted by tibimakai View Post
    Or may be you should try 5W-30 oil recommended in all other regions next time which may reduce your oil consumption.
  7. #172
    Join Date
    May 2013
    Location
    Posts
    2,700
    Then I would have 18MPGs
  8. #173
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,779
    I know you’re joking, right? But seriously using 5W-30 instead of 0W-20 the mpg reduction should be negligent. But it should help the oil consumption most of time. Based on Chris_Top_Her’s experience, 5W-30 oil also significantly reduced the contamination collected in his catch can.
  9. #174
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,004
    Quote Originally Posted by yrwei52 View Post
    I may try some 5w30. See how my next change goes and if I burn through a quart again.
  10. #175
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,004
    #2 - Thought I didn't run car long enough before sampling, but looks like it was good to go. Still awaiting report for ATF sample, sent in at same time. If I continue to run 7500+ miles like they say, I will be adding a quart of makeup oil at 5k as I was down a quart when I changed the oil last. Guess we'll see if that trend continues.
  11. #176
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,128
    Colorado, excellent results thanks for posting. The Castrol Oil I heard does a good job in keeping its weight stable during high heat.
    You came a long way....now fixing your car yourself and doing oil analysis!!!
  12. #177
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,004
    Quote Originally Posted by CX-5um View Post
    Castrol has been treating me just fine.
    Yes! Thanks to this forum.
    Still awaiting my transmission fluid sample report. Really looking forward to that one.
  13. #178
    Join Date
    Feb 2018
    Location
    IL
    Posts
    105
    Another good report. I'm curious to see if when you push it to 7,500+ you'll start seeing the same thinning I have.
  14. #179
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,004
    I'll let you know. Going to push this interval to 7500. Will have to add a quart though to do so around 5k from what I observed.
  15. #180
    Registered Member
    cx5 gt +pp 2018
    Join Date
    Dec 2018
    Location
    arizona
    Posts
    263
    first oil change cx5 2.5NA. mazda oil w/ moly 0w20 from factory. 2724 miles on the car.
Similar Threads
  1. Used oil analysis
    By Seminole in forum CX-5 Engine & Transmission
    Last Post: 04-24-2016, 09:49 AM
  2. My CX-5 UOA (Used Oil Analysis)
    By JTNY in forum CX-5 Engine & Transmission
    Last Post: 01-19-2014, 12:20 AM
  3. Replies: 20
    Last Post: 11-17-2012, 02:29 PM
  4. My Oil Analysis Results
    By Jasnall in forum Mazdaspeed3
    Last Post: 10-27-2009, 07:24 PM
  5. Oil analysis..who,what,where,when, and how?
    By Mike R in forum Mazda Protege
    Last Post: 04-24-2004, 01:35 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
