Rotated the tires on my 2016 CX5 and removed the caliper pin bolts on all 4 corners. They had very little to no lube on them. Looks like the factory skimped on the lube.
I removed the bolts and used synthetic brake lube on them. It's pretty simple and took my about 5 minutes per caliper. It's cheap and easy maintenance and will prolong brake life and provide smoother and even braking.
Torqued the front bolts to 25 ft.lbs and the rears to 20 ft.lbs
