2015 Mazda6 Bolt on "build"
jholso
2015 Mazda 6 Touring
Hey everyone, new to this forum. Ive had my 2015 Mazda 6 Touring MT since November 2014. So far I have done a few easy things since purchasing it.
Corksport axel back exhaust
Corksport shortshift kit
Corksport shifter solid shifter bushings.
Corksport LED light swap.
OEM navigation add on
K/N drop in air filter
H&R drop springs.
But this spring I have a few more bolt ons that I will be adding to the car. Im not going through this car nearly as much as I did on my past two cars (2008 &2012 Ford Focus) keeping it to bolt ons only.
I figured since the bulk of it is due in tomorrow Id get the thread started.
Airlift Performance bag setup
Airlift 3P management
Rotiform 20x9 INDT's ET35 in dark machined finishwith 245/35 tires
So far the 4 gallon tank, dual viar 400cc compressors, power wiring kit, and fittings have shown up. The rest of the air setup will arrive tomorrow. The tires and wheels will be in Tuesday and Thursday. Install starts Wednesday.
Here are a couple photos of how it sits now, Ill update this with more once the rest of the kit shows up and I start the install.
y3mTFy3P3OrphiWzqtvR_6Xx_6NqKDTeTDpLDpJJFR2x_sHI82o-2gX5WnvWFJj2eDEz9Ev6w-yYrwgThfV5rvFbHkPKRQR0aELdrDiNc4pJTXGncrY8_yHmAb5QaBukPPMaoscg058wjNbhOr_SLQsbURaUlGYj-ZhoHL6VovZyto
My driving buddy
y3mbU7y9dPAVtt17bivWssoWmE85pbRIparvebvFlK2Oa5wWw_XQODtxhVix7GpwtJJrTXz31vLOaiUIWOnjfJEMdlcQdqVBIt8d5RpCTW2tmINHpYokd0722ehMjfPwXPDfCVcvjbY12JaSlUo5P1av1GAIaMo0WwLZVX2_w95hU4
y3mZR6HlPkwmnnXblyB5-rCqbA9IVuJ8AQLloQJnZ9NuurKqD2jLtWtMWiorFmvGm6ZPlzFB-1v1Q79u0M_Y0N_Iu-iqWcz-ivTL7VFVN0H6KCSf_TNanHTtA2X2tDaADfBaQtYSjXvo1r7NeEN2wso96vZnQUoWJdNr4dYXA5PIYk
y3mS6dq-2dsBOjEF5_1ULz3-D_wyIqg3Bu54NcIfvofdWyYEmC0mzpvH9YoRf3Cxg9DtPs0SIUnYMqLqurUR7MbGtiefGgkeF5sys9r0AcumFhXydVC75dH_bxZwEz_1cZiW38LL-pCbvPR3W32hjHZ_p5xEYMnIsN-04yoYwxbJHc
And for good measure, old cars as a visual of where Im going but only bolts ons this time.
y3mlA4ytFrd-onUwNDVWyuEwzrMcMEn5IpUX284CQAewOKI7W9JWCk8N2dsj0lHZE7AFtEQZ3pPk62fqqPJ_wch6nxsJerdhpQ3AVeLqA3mS12HF8rSwOw8rj8i14mbpoU1EOOOvn1k6fG91hxAI7aV1w
y3mj9TTxNUZ-Atr0gGNDng-du1og_F4-EMGUIQmOnIc6Leo8dMunJBLiZI45aiaX8nrxpORolnovH31xfJdmxv2uJ92UkwOAV89H70nfOgcDmV9Q6tpWinOLzonudGIesc_XCW2sV90XK2hSHvm9-qvjw
Got the airride installed, and trunk setup mostly done. Need to get another warm weekend to take it back out, wrap it and add in the last couple items. But right now in the Northeast a warm weekend is not happening.
Everything went well. Huge thanks to Airlift and Bag Riders for their help with questions and getting everything to me I needed in a timely manner, including the second compressor wiring harness not really mentioned many places.
Install took less than a day, no real hiccups. routed the lined through plastic or rubber grommets so other than screwing in the power block and bolting down the trunk set up, I damaged nothing on the vehicle.
I will take better pictures when I pull the trunk setup out again. But here are a few.
y3ms4Eas9mivuR9yTuXk8POrG5LWPdRcdJaqvfFbD621yTUrzaFWy5fyX74fpKpGwEIbeg-z-TMgFAOE4LvjtRj-Cm6Z0SXtoDxYiLLmWeGV_XZ4YdsWvMvHzHiZauMpNL31FJkFc1dvgHKMFNkGuJfFun2vawO38pS-cQE3d4LPQk
y3m1I2E0zrT2Ci6sbw6NHylaC_tv4I_wsBKaNf1LLsEFg9c6B7N0miVkoxgNM6mvOXspsiizkD1qcZSFHv4Q9ny8yWRZfeppw9SFpgKLRKCBN5MTKqt-awIwpru257SeOvViYq_c76UuGYITwl1raj-E2nsMCITXwvwHHlbppqqq18
y3ml4lzdcdbs-XxAqOfbZ8iIoSQ-G-EM0dsAE3JBCkD29nDjl0ljQfPn9gNUm0ALvELwB586PLraMhg9lVuUb5ZC9bI9mFv219D3UbGWJGqt-fxVsfhQ35JMcwCNnLO57wAN8SyjVI3Fkos5_SwNtEZqOV03egWLMXyUVGQ7mMclUw
y3mX-EAFIOn6DsxMGM1cwd-dQv7svyVSC8XZyPbqfCAG9kXL2Lh1Of4imGSyfmNlleJyQ43p7v02Sc4JI3m7pdgxlm3KQ2ywD_d3XOx7dorEEu14108fQQXBP4gwHzotU6qKCoXr2VnvnPuv9-RGe6B4Y2O5NWazMTRuhbAqYxTsnQ
y3mUlCC-K5pNu9Ac7hGz6_WKhAuIAHd1SQ5n2HesEapS4RGo52mswhVP5vCbJ6PglXStkpaT5qwDNxraorXBfijK-aS9kLlJSb_vbK_oB_m6jhEja02epDHO4uWlOvmGVJV1bUJ8uBl26V52_RlNkF0Et_GnabqLbMHyXnzTPQOh8E
y3mHyne82kvPiYaROvP2dN5IOpyDCCi2qMR4ZCTk-TZ6eEE1b3JrNfQvvbtSPXv9nKF1ru2ZfsQj97la1DMz6nHIhTip5MynwJMXp8mhQFDcZmEdjiEtZvihpwWTQk9RZ87M9Kuk4N6-QdyhIFTC3xAiq7tj1K8XI2HDBlwLaUIoLY
y3m_2cGFkT_MF31vuH-lEhBKEyIeIra7L2bNVOkMIuY4WpavjK3nfm6WV8g16k_W4NBXuPWylGpZGMxN6uAme-UHqywfyxi6F7In-O-yOmt57_YDEYPyagEj9OZ5FIalkau1a4Qk5x3QpLJc6z4I1BQ6E5lMqt9KZnU607xiKgMWKk
y3mYK438yq9BrxSV88tV9lE5Vv1NfAazZACCOVrJgKW4i1_owDstkkQ7ybagKbZBR9PY60DF5kMyjciIK-YllSlvS_5DUEg2SqEDgxfqKCUBaqeJUtyY9xIqpy4AIrBcCrpoeSgTJnS5dQqEipjdrwNLvSE_dFjx8xvYzkMEas6hcY
y3muXFZTQF3Q1p_TG6n6B0_kkDnU_zhGjtN4C2041HDlbwmucPw6UXboI8q5jIg_A7ihaXx5vckV1L50rVyy9sqSu-AE6w3SkYQtTS93FYdtqJuyFbj_AJd0rfclniiIZA55ZaU1JKwGOuVWFIMYmUPuCHnQsduWCz_g_gWw2KiLCY
Latest posts
