2003.5 Sunlight Silver Mazdaspeed Protege
2003.5 Mazdaspeed Protege
Sunlight Silver Metallic w/ black interior
2.0L Turbo (Garrett T25)
Limited Slip Differential
182k miles
$4,300
More pics here: http://s367.photobucket.com/user/m_gerth/library/MSP ForSale
Bought it new in 2004 with 500 miles on the odometer from Diamond Mazda in Baton Rouge, LA. All work other than a few oil changes by Mazda dealerships has been performed by me. I enjoyed building this car for track days and it was my daily driver up until June 2015. Its loud and stiff by design but tons of fun. Ive since purchased a new daily driver and have a RX7 for track days. Unfortunately I dont have the room to keep this car as well. Registration will renew in March so the car will be freshly inspected.
Recently performed maintenance:
  • Timing belt w/ bearings/idlers/spring
  • Water pump
  • Accessory belts
  • Spark plugs
  • Valve cover gasket
  • Camshaft seals
  • Exhaust manifold original one cracked so I replaced with a repaired OEM one
    • All gaskets for manifold/turbo replaced
    • Copper coated nuts on all turbo connections
    • Turbo oil drain gasket & o-ring
  • Brake master cylinder
  • Rebuilt front brake calipers seals/bushings
  • Clutch master and slave cylinders
  • Cooling fan motors
    • New weather stripping around fan shroud
  • Battery and cable lugs
  • Windshield wipers
Modifications:
  • Replaced trunk and OEM wing w/ new wingless trunk
    • 3[SUP]rd[/SUP] brake light added to rear deck
  • Replaced pink tinted MSP tail lights with non-pink OEM Protege tail lights
  • Modified OEM Racing Beat rear sway bar w/ additional adjustment for stiffer setting
  • HardRace front control arms
  • Custom coilovers
    • Single adjustable Koni 8610-RACE shocks
    • Ground Control spring perches/adjusters
    • Eibach and Hypercoil springs 400#F/350#R
    • Cusco camber plates up front modified for more than -3.5deg of camber
    • Modified OEM top mounts on rear struts
    • Reinforced sway bar tabs
    • Professionally painted Pearl White
  • AWR adjustable sway bar endlinks front and rear
  • Custom short shifter reduces throw while bringing shifter closer to steering wheel
    • Custom machined black Delrin shift knob
  • DaveB brushed aluminum gauge rings in gauge cluster
  • AWR front motor mount
  • Reinforced OEM Mazdaspeed LSD original LSD cracked at 111k miles
  • 3 GHL SS divided wastegate downpipe w/ high flow catalytic converter and flex section
  • Custom 3 SS catback exhaust
    • Resonator and lightweight Vibrant Race-series muffler - loud
    • V-band connections and hollow hangers
    • Rear bumper lip trimmed to tuck exhaust up close to chassis
  • iON Performance front mount intercooler
    • front grille retained
    • silicone couplers w/ t-bolt clamps
    • heat resistant gold foil on all pipes in engine bay
  • K&N drop in panel air filter
  • ATP wastegate actuator - ~8-9psi
  • Split Second air fuel controller dyno tuned map
  • Greddy boost gauge in molded steering column mounting pod
  • Flex-a-lite cooling fans w/ shroud
  • PWR aluminum radiator
  • Mazdaspeed high pressure radiator cap
  • Heat resistant wraps on lower radiator hose and other water pipes
  • Stainless steel braided brake and clutch lines
  • Hawk HPS brake pads w/ Centric rotors
  • Enkei RP-F1 17x8 +45 offset wheels with 215/45/17 Dunlop DZ101 tires
    • Spare tire replaced with full size Enkei wheel & Federal 595R tire
Issues:
  • Needs paint work on roof, front bumper, passenger door handles and drivers side of car
    • Clear coat peeling and oxidized, scratches on bumper
    • Car had hail damage fixed a few years ago and I think the polishing thinned the clear coat
  • Headlights are hazy sanded/buffed a few years ago
  • Some tears in the cloth seats and scratches in plastics
  • Steering wheel is worn common problem and already replaced once
    • I have the original if you want to reupholster it
  • Holes in floor boards from Autopower roll bar and harnesses no longer installed
  • A/C needs recharged I believe the low pressure hose is leaking
  • Kenwood amp/subwoofer box needs repaired car is so stiff the amp keeps falling down
  • New water pump makes noise brand new Bosch part, no leaks but it is noisy
Accident History:
  • T-boned on drivers side in 2004. Other driver at fault.
    • Both doors, drivers window and B-pillar replaced
    • Repaired by body shop in MD
    • Some body filler used on rear fender arch
    • Paint on inner door frames has cracked over the years
    • Car drives and aligns perfectly
  • Drivers door, re-skinned in ~2008 due to a hit and run in a parking lot
    • Covered under uninsured motorist policy
  • A few low speed bumps to the front bumper
I have babied this car despite enjoying it at the track. The car has some wear and tear but the original clutch, transmission, and engine are a testament to how well this car has been cared for. I can bore you for hours on every little detail of the modifications and history. Regular and preventative maintenance has always been performed to keep this car on the road. High quality Mobil1, Eneos and Motul fluids used.
