first off i am going to assume you have a hatchback as the speed is a hatch back and its spoiler wont work or at least work well on a sedan, you could find a speed 3 at a junkyard ebay has replicas or amazon has unpainted ones (getting them painted is cheap) or even the dealer if you want to know exactly what your getting. the speed 3 wing should just bolt on to your car. all you do to remove your old one is take the trim panel off the top of the hatch and un bolt the nuts that hold the spoiler down and take the light out of your old one, then bolt the new one in and put the light in. if you dont have one you would need a trmplate and a drill to make holes for the studs and nuts to hold your spoiler down.
