It was -15F here yesterday morning. With controls in auto mode and set to 70 degrees, it warmed up nicely and plenty of air came out of the vents. As Woodys2718 mentions above, the fan starts out not blowing and then kicks in all the way to "almost full" when heat is available. Seems like plenty of airflow to me, but not sure how one could measure that. So to answer your original question, no I do not feel that the airflow from the HVAC vents is weak at all.
I was talking about rear adjustable center vents, in the back of the console, where you would expect to find them and not under the front seats.
I see, but that's not what you actually said. You said there weren't any rear vents.
In the winter the rear foot vents are key to drying out cold/wet shoes. I can't say I expected to see a center rear vent in addition but I guess your expectations are higher than mine. I could see additional rear vents if there were three rows of seating but the front vents and the two rear vents heat the entire cabin very evenly.
Rear "AC" vents are available on CX-5 competitors such as CR-V, RAV4, etc and Mazda6.I was talking about rear adjustable center vents, in the back of the console, where you would expect to find them and not under the front seats.Really? No vents in the back of a CX-5? I thought I read they did and my CX-3 definitely has......
The floor "heater" vents under the front seats for rear passengers are standard equipment since 1960s...
To OP, if you have this problem since recently, open the hood and check blocked inlet between hood and the base of the windshield such as leaves. If you have this issue since new, take CX-5 to your dealer for warranty service. Don't think the cabin filter is the culprit as your CX-5 is so new!
Like I said earlier, I don't think my expectations are unrealistic, talking into account that my car had a $32K+ window sticker.
I guess, based on your post, I might be too demanding of a $32K+ vehicle.
All these items don't make me regret my purchase because I like my CX-5 but it has several shortcomings that are annoying nonetheless.
I'm not sure if this has been asked....Have you checked to see if the vents are actually set to the open position? My wife frequently turns one or two vents off in my CX-5 and sure enough, it takes me days to notice.
My system warms very well and once there is warm air available, the fan kicks in strong--as if I reached over and turned it up to full.
Yeah they are set to the open position for sure. I've closed the passenger vent for even more power in the Center and driver vent.
Yeah, my 2015 Touring FWD 2.5L takes forever to warm up and never really does seem to put out a lot of heat. It does eventually warm up, but, it takes longer than past cars I've had.
I use the Auto Climate Control most of the time. I can say with certainty that its never switched to the dash vents when I'm using the heater during really cold days.
The only time the system has switched to the dash vents was when the AC was running and trying to cool the vehicle down. It makes sense to me. Warm air rises, so the vehicle uses the bottom vents when heating (excluding the defroster). And when its time to push cold air out it uses the dash vents.
