Page 1 of 15 12311 ... LastLast
Results 1 to 15 of 220
Thread: Change automatic transmission fluid?
  1. #1
    Registered Member
    mazda cx5 touring 2014
    Join Date
    Jan 2016
    Location
    United States
    Posts
    1
    I recently had 2 incidents where my transmission revved before going into 1st after backing out of a parking space. The engine revved when I pressed the gas then lurched forward. I have a 2014 Cx5 with 73000 miles. I checked the transmission fluid to make sure it wasn't low and it wasn't, but the color was a light brown. I read that the transmission fluid is lifetime, but am concerned that the color indicates the need to change. I called Mazda and they said they could flush the transmission for $200. Service bulletin 05-003/13 says "flushing is not recommended as part of service maintenance". The revving hasn't happened in several weeks, but I am gun shy from a transmission failure in another car. My neighbor suggested just draining a filling once/ year with ATF FZ.
    Also I see a tech service bulletin 05004 14 that talks about a whining noise from the transaxle at speeds greater than 10 mph on 2013-2014 CX-5 with VINS lower than JM3KE2BE3E0415164 (produced before November 11, 2013). My vin is JM3KE2CY4E0375203, so it looks like I'm in that group. I haven't had any noise but should I be worried?
    Any experience or recommendations would be greatly appreciated
  2. #2
    Registered Member
    Donated: $20
    2016 CX-5 AWD GT+iActive Soul Red
    Join Date
    Dec 2015
    Location
    NJ, USA
    Posts
    1,149
    Here it comes. What you'll hear is this: 1 whole group will say NOT to do anything. Another group will say: change it. In-between there'll be debate as to what LIFETIME means, as per Mazda.
    1 thing ONLY I can tell you: do NOT do flush. Do drain and fill. $200 seems a little high, in NY/NJ dealer charge $150.
    About whether to change it: I am equally confused.
  3. #3
    ZOOOOOOOOOM ZOOOOOOOOOOOM mazdadude's Avatar
    '16.5 Mazda CX-5 Touring AWD, '05 PRIUS
    Join Date
    Dec 2005
    Location
    Red Bluff, CA
    Posts
    3,448
    Quote Originally Posted by fre View Post
    http://www.mazdas247.com/forum/showt...D-on-a-2016-GT
    How did you check the transmission fluid?
    Mazda's I have owned over the years. (boom07)
    80' Mazda GLC SPORT MT - sold
    81' Mazda 626 DX MT - sold
    81' Mazda 626 LX AT - sold
    82' Mazda 626 DX MT - sold
    82' Mazda 626 LX AT - sold
    85' Mazda 626 LX MT - sold
    87' Mazda 626 GT Turbo MT - sold
    85' Mazda RX-7 GSL-SE MT- sold
    87' Mazda RX-7 Turbo 2 MT - sold
    91' Mazda Protege LX MT - sold
    92' Mazda MX-5 Miata MT - sold
    93' Mazda MX-3 GS-V6 Special Edition MT - sold
    00' Mazda 626 LX-V6 MT - sold
    02.5' Mazda Protege5 MT - sold
    06' Mazda 5 Touring AT - sold
    13' Mazda CX-5 Touring AT - sold
    14' Mazda 3i Grand Touring MT - sold
    15' Mazda CX-5 Touring AWD AT - sold
    03' Mazda Protege5 AT - sold
    16.5' Mazda CX-5 Touring AWD AT - current
    09' Mazda Mazdaspeed3 GT - current
  4. #4
    Registered Member erhayes's Avatar
    Donated: $10
    Mazda CX-5 FWD Touring
    Join Date
    Jan 2007
    Location
    Cape Coral, FL.
    Posts
    2,769
    If you are able to do a plug drain and refill, then you may want to consider it. However: the issue you are describing suggests a electronic problem rather than an old fluid problem. I would ask a Mazda rep, (not service writer) if there has been an update of the AT software. Ed
  5. #5
    Registered Member
    2013 CX-5 Touring
    Join Date
    Sep 2012
    Location
    Houston, TX
    Posts
    381
    I sent in a sample of my transmission fluid at 50K to Blackstone Labs (fluid looked great) and I asked them about "lifetime" fluid. Here's their response. Note that they have nothing to sell me related to this, and fluids are their business.
    "We can't say the manufacturer is wrong. After all, they designed the transmission and they are the ones to replace it if/when it fails. Still, the oil itself has a limit as to how much metal and insolubles it can hold before it becomes abrasive, and for that reason, we think the oil should be changed at some point.
    Oils that have been in place for 100K miles or more are often full of wear-in material and any accumulation over the course of those 100K miles, and in some cases, the oil can actually stay in place longer, while in other cases, the oil is abrasive and full of insolubles, which cause more wear overall.
    It's hard to put an interval on it, but you've done the right thing by checking in at 50,000 miles. This way, you can get an idea of how things are going and if/when you need to change it next.
    The basic rule of thumb is that changing the oil doesn't hurt anything, but leaving it in place for a long time can cause excess wear, which could've been avoided with shorter intervals.
    My vehicle also has a "lifetime" fluid, and I don't know what they were trying to achieve by designing it this way."
  6. #6
    Registered Member GP 2004's Avatar
    2015 CX-5 GT AWD liquid silver
    Join Date
    Dec 2014
    Location
    Chicago suburb
    Posts
    652
    I would not do a flush. I would do a drain and fill myself. Use Mazda approved fluid.
  7. #7
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,088
    A drain and fill of approx. 5.1 US qt, per service manual is pretty much the only service regarding the ATF. Above that is dropping the pan, and replacing the strainer (and bolts for it). If you have to drop the pan because of a clogged strainer or excessive particles, you are probably having a major failure somewhere.
  8. #8
    Registered Member
    '14 Sky Blue CX-5 GT w/ Tech
    Join Date
    Aug 2013
    Location
    Pittsburgh, PA (USA)
    Posts
    244
    Mazda claims "lifetime" transmission fluid, but they don't warranty the transmission (in the US) beyond 5 years or 60k miles. Perhaps they only mean the "lifetime of the warranty"?
  9. #9
    Registered Member
    2016 CX-5 Sport AWD
    Join Date
    Jul 2015
    Location
    PA
    Posts
    171
    Many manufacturers state that their transmission fluid is a lifetime fluid. I find that total BS, ATF should be drained and refilled every 30-50k depending on your driving habits. Some may say that is overkill, but better be safe than sorry.
  10. #10
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,004
    Quote Originally Posted by garyd9 View Post
    Exactomundo!! Once that drivetrain warranty expires they are free and clear with the exception of recalls probably. Car Manufacturer lifetime = warranty period. If you plan on keeping your car past that period you better change your fluids. There's no question there. The debate lies in when to do so!!
  11. #11
    Registered Member Lbear's Avatar
    2017 CX5 AWD Touring
    Join Date
    Oct 2008
    Posts
    911
    If you tow I think every 25k miles would be ideal but 30k miles would be doable. If you DON'T tow then 40k miles would be good.
    That's just my opinion.
  12. #12
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,312
    Get a 100K mile warranty.
    Service the vehicle by the manual.
    This is always the safest bet.
  13. #13
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,312
    Quote Originally Posted by CX-5um View Post
    I disagree. I know people with vehicles that have transmissions which have gone hundreds of thousands of miles without fluid changes. Yet the only 3 vehicles I've owned with automatics that got transmission fluid changes, each and every one had issues afterward, 2 of which ended up in complete failure, and 1 just in driveability issues. The highest mileage was 110K, the lowest was around 70K.
  14. #14
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,755
    Blog Entries
    6
    IMO... nothing wrong with a drain an refill on a vehicle you know the "full" service life on. A used vehicle..... that is another matter but I don't recommend the full flushes either.
    This formula has always worked for me.
    '15 CX-5 GT 2.5L w/tech package - 49K Miles / '07 Infiniti G35x / '12 Lexus GX 460 / '00 Wrangler TJ 4.0L
  15. #15
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,004
    Quote Originally Posted by Unobtanium View Post
    You may disagree with me but I agree with you lol. Here's how:
    Long story short with considerations into BMW's steptronic transmissions. The general rule was to change the tranny fluid before certain "K" miles. I have to admit I forgot exactly the amount 50-60k? Anyways the rule says if you're past a certain "K" miles DO NOT Change the tranny fluid because doing so will cause more harm than good. With harm I mean complete tranny failure harm. BTW, VW's DSG transmissions requires fluid flush/changes otherwise warranty can be voided.
    Long story shorter: I'm replacing fluid aprox every 40k miles (40/80/120) via drain fill for both our newly owned Mazdas. I would think twice and research further before replacing transmission fluid for the first time on a car nearing high mileage. In BMW's case, transmission fluid at say 100k miles has valuable metal shavings in it that changing it out for new fluid would cause failure. That problem is avoided by just leaving the fluid alone or an earlier and then scheduled fluid changes which is what I'm doing.
    Interestingly, I've been turned down by at least 4 shops (3 tranny shops) for wanting to flush/fill my BMW's auto transmission. Their first question was "what is the mileage". Their answers, they do not want to be held responsible for costly damage.
Similar Threads
  1. Automatic Transmission Fluid - Can you change it?
    By brilloAMD in forum CX-5 Engine & Transmission
    Last Post: 06-08-2015, 09:42 AM
  2. Regarding automatic transmission fluid.
    By markuszoom5 in forum Mazda5 Lounge
    Last Post: 10-06-2013, 07:36 PM
  3. Automatic Transmission Fluid
    By joshritger in forum Mazda3 Engine & Transmission
    Last Post: 09-10-2009, 12:31 PM
  4. Fluid capacity [automatic transmission]
    By Vozac in forum Other Mazdas
    Last Post: 07-28-2005, 01:54 AM
  5. Automatic Transmission fluid??????????? S
    By catchme31 in forum Protege5
    Last Post: 02-13-2005, 09:24 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
