Depending on which side:Too much info...head...is...exploding!!!!
IF JEEP - then use the spinal cord to lock up the side.
IF CX-5 - rub the affected ear real good.
On a serious note - that moron's approach to get out of the snow, it's actually very common where I live, in NJ/NY and the snow trucks dumping snow. So - let's take a step back and may I ask? If in such situations and you happen to have a CX-5 AWD what should be the correct approach to get out the snow? Assume all-weather tires since that's what most seem to have...
All weather tires are a new class of tires between snow tires and all-season. The vast majority of drivers are on all-season (not all weather).
Regardless of what kind of tires you have, the answer to your question doesn't really change (although the chances of needing an answer in the first place is many times lower with winter tires).
The Jeep driver's primary mistake (beyond crappy tires) is his apparent belief that a heavy right foot and persistence is the key. His second line of attack is lacing his incantations heavily with profanity. Neither of these strategies have ever panned out for me so, for the previous 30 plus years I have remained cool as a cucumber.
The first line of defense is not to get stuck in the first place. This means is that at the first sign of potential trouble you avoid the temptation to power out. You might get out but, if you don't, you WILL make it worse. So don't try. The sooner you realize you MAY be stuck, the better. Apply the brake, exit the vehicle and survey the situation behind/in front of each tire. Knowledge is power. Gravity is your friend. I carry a small mountaineer's shovel in my cargo area all winter (only weighs 18 ounces). The flatter the shovel, the better. Deep pocket shovels compromise their ability to get in tight to the wheel. Remove one scoop of snow from both sides of each tire. This takes about 30 seconds total. You have already surveyed the situation so get back in the vehicle, turn your wheels in the direction favored by gravity apply power as gently as possible and, if you followed the previously steps properly, 99% of the time you will drive right out. If not, you broke the #1 rule (don't get stuck in the first place). In three years of driving the CX-5 in challenging, steep, slippery and rutted conditions, I've never been stuck.
The #1 rule has ALMOST nothing to do with which AWD system your vehicle has and EVERYTHING to do with tires (protestations from some snow neophytes nonetheless) and winter driving skills of the driver. These skills have nothing to do with summer driving skills (although they are closely related to off-road skills). The most common error I see (both before someone get's stuck as well as after they are stuck) is people ignore gravity. Look at which way the crown of the road slopes and which tire may be stuck in a hole.
Specific to the Jeep video, his primary problem (besides crappy tires and poor driving skills) is the road has a pretty steep crown (he's in a gutter). His problem is not the AWD system of the Jeep. It's probably about equal to the excellent CX-5 AWD system in this particular situation (however, for driving 40 mph on a curvy, icy road with a steep crown, the CX-5 system is considerably superior). Obviously, the best way out of there is forward. As soon as he realized it wasn't an easy drive out he should have cleared a path that didn't have any snow bumps in the way. There was also deep wet snow in between the tire paths that was pushing against his underbelly (the jeep has about the same ground clearance as a CX-5). Had he cleared such a path, he would have extricated himself on the first go.
-How do you figure the CX5's awd system is better at anything, assuming he has QD2 in the Jeep?
-The jeep has 20% more ground clearance than a CX5
-locking in the axles changes the entire ECM parameters, and would allow the jeep to crawl out much easier without upsetting traction.
Hmm, I wonder if the turbo will make the AWD engage while WOT from a stop and make the car do a wheelie? I wonder how easy it will be to convert the car to FWD after that event?
WANT THIS if I really need : https://www.youtube.com/watch?v=J2uIlfqRkyQ
lol the sky-d is basically just as powerful as the diesel in that thing.. and gets more mPG
Defying instinct and not touching the brake in a skid takes a lot of skill and guts. The best thing is to get yourself on a big piece of open ground and play in the snow.
Regarding how the CX-5 would compare with the Jeep dynamically, I suspect they might behave in a similar way to most drivers UNLESS it was snowing and one of them had proper winter tires and the other didn't. Then the odds start to swing.
What has served me well for 47 years of driving in inclement weather is to go gently on the gas, gently on the brakes. I start braking way earlier than I would on clear pavement and no sudden inputs to the steering wheel. Everything is done gently to keep the car in balance. Braking early also warns the car behind you to slow down.
