Yes I am aware that there is already a post about this, however there was no real answer to the problem. I accidentally connected the illumination wire in the radio loom to a cam control wire, instead of covering it and putting it away. As a result, my parking lights, tail lights, instrument cluster amber lights, and ac control amber lights do not turn on. I have checked the fuse and replaced it, didn't fix my issue. Checked the tail fuse in the other fusebox next to the engine, nada. Checked the switch, nothing was blown, switch works in a different p5. I have checked the connector that the switch connects to, and using a multimeter I have observed that upon turning the lights on in both sockets it applies .85mv of power when turning the lights on. I noticed that upon tapping the brake pedal this number goes up significantly. What I should do? what are my options? I can't drive at night until this issue is fixed.
