- RDX Aspec Adv.
A while back I read how these vehicles used oil. So, I waited...I have about 4700 miles on this oil change, and I went out and checked the oil level. Assuming you divide the space between the top hole and bottom hole in the dip-stick into 4 equal blocks, the oil right now is sitting at 3 blocks full from the bottom hole (1 block down from the top).
As I recall, this is exactly what it looked like when the oil was last changed. I am sure *some* oil was used, but I would not even come CLOSE to considering even adding 1/8th of a quart at this point. It's just fine.
