a lot of noise
yakishalom
mazda 5 2012
hello
i bought my mazda 5 - 2012 six Months a go.
From the beginning when i used the radio in fm mode
is play with a lot of noise (never mind what station he is)..
Meanwhile, i replace 3 multimedia radio and there is still noise.
one week ago i replace the mount base and the antenna...
again still noise...
what i can do to hear clear station in fm mode?
hello
Try a few tests.
1. is the noise only when the car is running?
2. connect a external antenna to the back of the radio. Did that help?
3. disconnect battery terminals from battery and use jumper cables to connect to another car's battery. Did the noise stop?
4. is it a factory antenna? make sure it's screwed on and not cracked or broken.
Try a few tests.
1. no even when the engin down.
2. before i try this because i need to open a lot of think to get to the multimedia mybe there something easy more to try.
3. not the battery problem.
4. change the factory antenna with new factorry antenna and he close perfect.
any suggestion?
