Updated parts list.
Where else am I supposed to source everything from? Walmart down the street? You think I'm going to spend 2,3,4+x on universal parts on a setup that no one else has claimed to have done on this car? Numerically, most of the parts are low priced tubing and fitting anyways. There are plenty of turbo set ups using "ebay" (as if it's a brand) parts that are not OEM. There is always room for improvement later once everything is working, if/as needed. That's uncommon at all with builds you find on tuner pages. The expensive part of any turbo build is the turbo itself, maybe the manifold and any custom work you have to pay for. Since there are not skyactiv manifolds, pre-bent and cut downpipe tubing, intercooler etc for this vehicle/engine there isn't really anything expensive to buy. The single most expensive item that I currently have on the list is the turbowerks pump. That's a critical item so money will be spent there. Not going to buy a $1000+ turbo when I can get an "ebay" turbo for < $200, have it rebuilt at a turbo shop for ~$100 for assurance and run it. And if it doesn't work out I didn't buy an extra expensive part. I will be checking home depot etc for the oil line and fittings as they usually sell fittings cheaply, for now I have an online source.
Personally I would splurge a bit on the BPV/BOV. Those cheap ones tend to leak (hell even some name brand ones have a bad reputation). GFB makes some really good products and won't kill you on price like Turbosmart or HKS. Tons of guys in the Suby community run them with great results.
Also on going the route of a no name intercooler. I would definitely water/pressure test it to make sure all of the welds are good before installing. After that it is really just how well the core is built/designed.
Oh . . . and don't forget gauges. Boost and oil pressure are great places to start. Probably already on your mind since you are getting the oil sender adapter, just not on the parts list.
