CorkSport.com is MAZDA PERFORMANCE!
Results 1 to 9 of 9
Thread: 02 Protege with Rough/Dying Idle and P0302 + P0171 Codes
  1. #1
    Registered Member
    Mazda, Protege DX
    Join Date
    Sep 2015
    Location
    Ohio
    Posts
    3
    Unhappy 02 Protege with Rough/Dying Idle and P0302 + P0171 Codes
    Hello everyone,
    My father and I recently replaced the head gasket on my 2002 Mazda Protege DX (2.0L Engine). Since then, I have had a rough idle that I simply cannot get rid of. The car only has problems when at a complete stop or crawl speed (like moving up a car length in an intersection). When it is actually driving it runs smooth as can be, highway and backroads. The odd thing is that the car runs only slightly rough right after start up (when the engine is cold) and progresses to where it bogs out and dies/almost dies after the engine has warmed up. After the car is actually driven for any length of time, it has a fairly violent idle and dies within 30 seconds of stopping.
    At first the idle was very rough and throwing only a P0300 code (Random Misfire). My dad and I tried many things to fix it including:
    Replacing all coil packs and wires
    Replacing all spark plugs
    Replacing the EGR Valve
    Replacing the PVC Valve
    Replacing the IAC Censor
    Cleaning the MAF Censor
    Spraying throttle body cleaner around the intake manifold to check for leaks. (The engine did not rev, so we're guessing there's no intake leak.)
    After doing all of this, nothing was fixed, but we did find that running the A/C made the car run smoother. My father also adjusted the idle up just a little bit. (Which I later read is not supposed to be messed with. ) It still had a rough idle, but was not at the point of dying, so I went with it.
    Now after a week or so, the idle has gone back to almost dying, even with the A/C on. I did another OBD-II scan of the Check Engine light and now it it is throwing a P0302 code (Misfire in the 2nd cylinder) and P0171 (Engine Running Lean). We're now thinking that the fuel injectors may be the issue, but after a quick test (putting a screwdriver up to the injector and our ear to the other end.) It sounds like all for injectors are firing at a constant rate. So we're not sure there.
    I am so frustrated and low on funds that I can't keep throwing money at the car if it's not going to fix it. The mechanics we've spoken too are pretty puzzled too and told us they'd be doing nothing more than guessing fixes too, and I can't pay them to guess, lol.
    I didn't know if anyone on here had any advice on what to check next. Obviously with the head gasket repair, we took most of the engine apart to get to the head, so it could be a number of things wrong. We do however know that the head gasket was installed correctly, because there is no longer air bubbles in the coolant and the car does not overheat. So we do not believe that the misfire is due to the head gasket. Also I'll note that the actual problem with the "head gasket" was that the head was warped. An engine shop we took it to milled 8 thousandths off the head to get it flat again.
    If any more info is needed, please let me know. Sorry this is so long, I wanted to be thorough since we've done quite a bit to the car already. Thanks!
  2. #2
    Registered Member concept's Avatar
    2014 Mazda3 S GT auto, 2008 MX5 6-speed
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,652
    Does it idle okay if you throw the transmission into neutral? If so, check the auto transmission fluid level (while in Park or neutral and after the engine is warmed up)?
    I had a similar problem with my MX6 GT. Once I brought the trans fluid to proper level on the dip stick, the smooth idle returned and all was well. Apparently, one of the valves wasn't functioning properly with low fluid, and the trans wasn't shifting into first gear.
    2014 3S GT, Deep Crystal Blue, Eibach Pro-Kit, Enkei PF01s, Koni Sports, Pirelli P ZERO ALL SEASON PLUS tires, 225/45/18
    2008 MX-5 Touring (Mazdaspeed CAI, HIDs, Progress/Koni Sports/Racing Beat sways, SST Magnaflow muffler and tips)
  3. #3
    Registered Member
    Mazda Protege 2000
    Join Date
    Jul 2013
    Location
    Florida
    Posts
    22
    check the brake booster hose and the big intake hose for a vacuum leak
  4. #4
    Registered Member
    Mazda, Protege DX
    Join Date
    Sep 2015
    Location
    Ohio
    Posts
    3
    No, it's less noticeable from inside the car when it's in neutral, but the engine does not behave any different.
  5. #5
    Registered Member
    Mazda, Protege DX
    Join Date
    Sep 2015
    Location
    Ohio
    Posts
    3
    I've already checked the big intake hose. (Actually had it replaced less than a year ago, so it should be good.) I haven't checked the brake booster hose though, I'll have a look at that tomorrow.
  6. #6
    Registered Member
    Protege5
    Join Date
    Mar 2014
    Location
    United States
    Posts
    20
    Did you get this resolved? I'm in the same boat with a 2002 Protege. Have done everything you mentioned and no luck. Mine is a little different in that it idles smooth with a/c off, then sputters with a/c on. Also smooth in Park, same sputter in gear. I've also let it idle with the pcv valve both plugged in and not, no difference. Same with the EGR connected and not. Did the same with IAC. It won't idle by itself when disconnected, but I can hold it at idle speed with the gas pedal and all the symptoms exist. At my wit's end.
  7. #7
    Registered Member
    03 Protege LX
    Join Date
    Feb 2017
    Location
    US
    Posts
    10
    I'm sure the car is either gone by now, or been fixed. However I just did my head gasket, valve stem seals, timing belt, water pump, and after assembly ended with the same problem. Ensure that the intake manifold gasket has been installed properly and creates a tight seal. That fixed my problem.
    Sent from my VS986 using Tapatalk
  8. #8
    Certified Mazda Tech hornsfan10609's Avatar
    2003.5 Mazdaspeed Protege x2
    Join Date
    Jun 2009
    Location
    Austin, Tx
    Posts
    8,125
    Timing is probably off
    Mod List. "Jinba Ittai"
    2003.5 Titanium Mazdaspeed Protege #1345 Purchased 7/20/10
    2003.5 Titanium Mazdaspeed Protege #1574 Purchased 10/25/14-SOLD
    2003.5 Titanium Mazdaspeed Protege #32 Purchased 3/23/19
    2003.5 Laser Blue Protege5 Purchased 6/17/17 SOLD
    2009 Highland Green Mustang Bullitt #5998 12.9@110
    2002 Red Protege5 RIP:4/25/10
  9. #9
    Registered Member
    2003.5 MAZDASPEED Protege #2218
    Join Date
    Oct 2019
    Location
    Northern KY/Cincinnati OH
    Posts
    10
    has anyone found the fix to these problems?
    I recently bought a 2003.5MSP with the same issues and throwing
    the same codes P0302 & P0171.
    part store ran a list of 15 parts that could fix it... but I don't wanna replace parts not needed.
    thanks
Similar Threads
  1. Hesitation at high rpm/under boost p0302 and p0171
    By mattkohut in forum Mazdaspeed Protege
    Last Post: 03-10-2015, 01:43 PM
  2. Replies: 15
    Last Post: 05-02-2013, 08:14 AM
  3. Replies: 4
    Last Post: 12-27-2011, 12:01 AM
  4. Couple of codes and rough idle.
    By baconbitz in forum Mazda6 Engine & Transmission
    Last Post: 06-07-2008, 01:30 AM
  5. Diagnosis - P0171 and rough idle
    By iluvmacs in forum Protege5
    Last Post: 09-29-2007, 12:23 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
