Cowl Grille: How to Remove? B2600 Specs provided
G
Geazer
1990 Mazda B2600i Cab+ SE Pickup, 6' Bed, 2WD AT, AC
Seeking instructions to remove Cowl Grille, that tells all fasteners to be removed. Cowl Grill is located between hood & windshield. Has slots for HVAC air intake. Wipers are set into Cowl Grill. Intent is remove & paint. Removal is also first step to accessing wiper motor.
{Please do not post or send comments on font color, style or size.}
Below are some specifications from original Owners Manual which I have:
Made Sept.1989 as 1990 model year in Hiroshima Japan. Sold new 1/24/1990 locally.
Engine: 2.6 Liter, 4 Cylinder SOHC, 12 valves. 121 hp (90 kW), 149 lbft (202 Nm). Bore and stroke are 92.0 mm and 98.0 mm. Fuel injection. 2.6 Liter- Offered in USA for Mazda PU from 1988-1993.Also used 1989-1996 in Mazda MPV {mini van}.
Automatic 4-speed with Overdrive. Shifter on floor.
Curb Weight 3095 lbs + bed liner- unloaded. GVWR 4,500 lbs. Payload 1,405 lbs.
Turning Diameter 39.40 in.
Overall Length 193.70 in. Overall Width 65.70 in.
Overall Height 61.60 in. Wheelbase 117.50 in.
Track Front 55.10 in.
Track Rear 55.50 in.
Front: Torsion Bars {no struts}
Rear Spring Type: Leaf
Front Headroom 38.60 in. Rear Headroom 36.80 in.
Front Legroom 42.40 in. Rear Legroom 28.00 in.
Brakes Type Power: Front Disc. Rear Brake: Drum
Gas Tank 14.80 gallons. Regular unleaded.
Oil: 5 quarts 10w40
AT: 7.90 quarts Dextron II
Cooling: 7.90 quarts 50/50.
Rear differential: 1.4 quarts 80-90 gear oil.
EPA Fuel Economy (MPG) 2600 cc, Automatic 4-spd with OD, Regular Gasoline:
City 19 & Highway 24
Bed 6 feet 2 inches long. Outside top size: Long 74 x 61 Wide.
Vinyl Mazda bed liner. 4 tie down steel loops inside bed corners.
Mazda step bumper with under mount Reese style hitch. 1 1/2" square receiver.
Looks to be a class III hitch?
200 lbs. tongue load max, 2,000 1bs trailer load max. {Engraved on bumper.}
