Mazda of the Month | ENTER NOW for September!
Status
Not open for further replies.
Antoine
Administrator
Please note the following rules & guidelines.
Your cooperation and participation would be greatly appreciated, thank you.​
ENTRY RULES:
* You must own the Mazda you are entering into the contest
* Any form of photo/image manipulation is not allowed except for adjusting and enhancing image color, contrast, tone and levels etc
* If you wish to enter two or more times in a row, you will need all new photos of your Mazda for each consecutive month entered
* Once you have entered (posted) your Mazda, you may not withdraw from the contest
* The MOTM contest & rules are subject to change in order to maintain a fair & fun environment for the Mazdas247 Community
ENTRY REQUIREMENTS:
1. Username
2. Name
3. Year and Model
4. Minimum 2 pics / Maximum 5 pics of your Mazda *NO ATTACHMENTS PLEASE!
5. List of CURRENT modifications *NO "WAITING TO BE INSTALLED" MODS PLEASE!
EXAMPLE:
Antoine
Antoine *
1995 Eunos Cosmo
- Hi-Per Coolant
- Redline Diff Oil
- Autoexe Intake
- Autoexe Springs
- Volk Racing Rims
- HKS F-CON V Pro
- Redline Tranny Fluid
- Titanium Intake Pipe
- HKS Boost Controller
- MAZDASPEED Exhaust
- Speedmaster Engine Oil
- Optional Factory Aerokit
- Paint Protection Coating
- Carbing Front Strut Brace
- Autoexe Spark Plug Wires
- Alpine Navigation Headunit
- Yokohama DNA S.drive Tires
- Defi Boost Gauge & OLED Display
- Upgraded Original Headlights (HID)
- Carbing Cooling Plate (not pictured)
- Custom Center Console and Glovebox
PRIZES:
Provided by the International Motor Sports Association | IMSA.com
* Hot Pass for Winner and Guest at one of the Winner's choice of TUDOR Championship races in 2015
* Behind the Scenes Tour including being on the Starting Grid for the race, Transporter Tours and a visit to Race Control
* Exclusive Pit Lane access during race
Many thanks to the IMSA | TUDOR United SportsCar Championship for this fantastic prize!
In addition to...
+ Free Basic Custom Shift Boot * Boot compatible with NA & NB Miata, Gen 1 and 2 RX-8, Gen1 and 2 MAZDASPEED3 / Mazda3, 3rd Gen Protege and MAZDASPEED6 / Gen1 Mazda6 * OR + 20% of next purchase up to $200 THANKS TO FattiMotorWorks.com
+ Your Mazda showcased on the Mazdas247 Home Page!
+ A Mazdas247 T-Shirt and a pair of Mazdas247 Decals!
-> Sponsor a Future MOTM...PM Antoine for details!
VOTING RULES:
* Votes only count for the MOTM from those Members that have joined Mazdas247 during the previous month or before
* There is NO tolerance for PERSONAL CAMPAIGNING threads, posts, private messages (PMs), images or links (including signature and or image links). The creation of such ANYWHERE on or off the Internet including Mazdas247 will result in immediate disqualification...If you are disqualified, your entry & poll listing WILL remain but your votes will be removed
* Creating GENERAL "Vote for the MOTM" threads and links is allowed and encouraged
GOOD LUCK AND HAVE FUN!
This month's theme is...
Hatchbacks, Crossovers, Wagons and SUVs
PLEASE DO NOT ENTER if your Mazda does not match the above theme, thank you!
DEADLINE to ENTER is September 15th '15!
NOTE: Please keep this thread ON TOPIC.
Thank you and once again, good luck!
Loud3
Nathan O'Donnell
2014 Mazda 3 Touring
Air suspension functions
19x8.5 Volk Racing (Rays Engineering) G25 wheels
Rays Engineering forged lugs
235/35/19 Yokohama Advan Sport tires
AirForce air suspension struts/bags/shocks
Accuair air suspension management
Shaved rear hatch
Ultimate Racing titanium performance mufflers
Llumar ceramic tint
color0
Brian Ma
2013 Mazda3 i Touring
Power/MPG:
  • Cut-airbox SRI
  • JBR Skyactiv Panel Filter
  • Custom Magnaflow 11132 exhaust w/ 3.5" exit
  • Ford E-Focus Rear Motor Mount
Chassis/Suspension:
  • BC Racing ER Coilovers w/ custom digressive valving
  • Swift Springs 9kg/mm F
  • Hyperco Springs 650lbs R
  • SPC Rear Camber Arms
  • Corksport 28mm RSB
  • Hotchkis Billet Sway Bar Brackets
  • Corksport Rear Toe Links
  • Tri-Point Rear Endlinks
  • Powergrid Front Endlinks
  • GTSPEC Front Strut Tower Bar
  • Corksport Mid-Chassis Brace
Brakes:
  • Mazdaspeed3 front brake conversion
  • Mazda5 rear brake conversion
  • Stoptech Street Performance pad set for Mazdaspeed3 F/R
  • Stoptech stainless lines F/R
  • Edelbrock speed bleeders
Wheels/Tires:
  • Enkei NT03+M 18x10.5 +30 F/R
  • Bridgestone RE-11 285/30/18 F/R
  • Eibach 10mm spacer F
  • Adaptec 12mm spacer R
  • ARP extended wheel studs
  • Muteki SR48 Burning Blue Neon lugs
Exterior/Aerodynamics:
  • Garage Vary Replica Front Lip
  • BMSPEC birch plywood front splitter
  • 240ZG Fender Flares
  • Bayson R side skirts
  • SPMS P1 Spec Rear Wing
  • BMSPEC custom wing risers
  • BMSPEC custom rear diffuser + subframe
  • VG Sharkfin Antenna
Interior:
  • Flush-mounted BC rear damper remote adjuster
  • Custom eccentric aluminum shift knob
Lighting/Electrics/Misc:
  • Hella Optilux Extreme Yellow 65W 9005 high beams
  • Hella Optilux Extreme Yellow 55W H11 low beams
  • Corksport LED Hatchback Brake Light
  • Brake light flasher circuit
  • Hella Supertones
  • Rear wiper delete
bigsho
2007 Mazdaspeed 3 GT
Sohan Ghosh
Suspension/Braking/Handling:
-Mazdaspeed Accessory Coilovers
-SPC Camber Arms
-Whiteline Adjustable Endlinks Front and Rear
-Hotchkis 32mm Front and Rear Sway Bars, rear is on stiffest setting
-OEM Mazda Brake Rotors
-Hawk HP+ Front and Rear Brake Pads
-17x8.5 +40 Enkei RPF1's with 245/40/17 BFG G-Force Sport Comp-2 tires
Built Motor stuff:
-88mm Manley Platinum Series Pistons (stock CR of 9.5:1)
-Manley H-Beam Rods
-Polished and Balanced Crank
-Refreshed Head
-All mazda OEM gaskets, head/main studs, bearings, etc
Engine/exhaust goodies:
-Autotech HPFP Internals
-HTP 3.5" Intake
-COBB Front Mount Intercooler (red piping and black core)
-Custom 2-piece 3" Catless Vband Downpipe with Top Portion Ceramic Coated
-Secondary O2 Sensor Delete
-Forge V1 Bypass Valve
-Mazdaspeed Accessory Catback Exhaust
-COBB AccessPort v3
-Cp-e Stage 1 75 duro Rear Motor Mount
-PnP Intake Manifold with VTCS Delete
-Sikky Manufacturing Thermal Insulating Intake Manifold Gasket
-James Barone Racing EGR Blockoff
-Kozmic Primary EGR Delete with Coolant Line Plug
-Kozmic Screamer Pipe
-Precision 5858CEA Journal Bearing Turbo with 4" Ported S Compressor and 2.5" Vband Outlet
-Precision 46mm External Wastegate
-Cp-e Vband Exhaust Manifold (Ceramic Coated)
-Cp-e Safe Seal Injector Seals
-James Barone Racing Stage 2 Oil Catch Can
-DIY Throttle Body Coolant Bypass
-James Barone Racing Thermal Insulating Throttle Body Gasket
-Bosch 3bar MAP sensor
-Grimmspeed 3 Port EBCS
-PTP 1950psi Relief Valve
-Tune by Realgib3
Status
Latest posts
