Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 131
Thread: How long did your brake pads last?
  1. #61
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    You will notice though most impact wrench sets all use 6-point. IMO.. it's more important on high torque applications.
    '15 CX-5 GT 2.5L w/tech package - 53K Miles - https://www.oemvehicleparts.com/ (30% off "shipping" with code "MAZDAS247")
  2. #62
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,298
    Arrow How long did your brake pads last?
    Quote Originally Posted by Kedis82ZE8 View Post
    Everything here was included in the hardware kit.
    The only redundant items with brake pads were the brown and black grease packets. Just pads and grease. Nothing else pictured above came with pads.
    OK, good to know. For the price I'd do the same replacing these old shims and springs and more grease to boot!
    The shim kit you ordered is for non-EPB only, I've to find correct PN for my 2016 CX-5 when the time comes.
    Is there an instruction telling you the difference between these two greases? I imagine brown grease (rubber friendly) is for sliding pins and black grease (moly, anti-rattling) is applied between shim and pad?
  3. #63
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,298
    Arrow
    Yep. No doubt 6-point is the safest!
  4. #64
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    The black grease is for the back of pads. The brown grease is for the contact points on the side the pads have with the shims.
    I just used some Sil-Glyde I still had from other brake jobs for the slide pins.
  5. #65
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    I think you are looking for KAY02649Z for '16+
    https://www.mazdabestpartsonline.com...-kit-kay02649z
  6. #66
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,298
    Good to know. So I assume there's no instruction telling us which grease is for which.
  7. #67
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    It came with instructions showing where to apply each grease. I'll scan or take a picture of them.
  8. #68
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,298
    Arrow
    This one doesn't come with the grease packets ⋯
  9. #69
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    It may not be listed. Here is a kit with the same PN on a Russian site that shows the packets.
    EDIT: It does have an "A" at end of PN so not sure if that changes things.
    EDIT: Actually it says K0Y1-26-49ZA
    http://shopcx5.ru/catalog/tormoznaya_sistema/KAY02649Z/
  10. #70
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,298
    Thanks for the info. I definitely would prefer getting K0Y1-26-49ZA with grease packets if possible. Luckily I just got a new set of rear disc pads、rotors、and revised calipers under warranty based on EPB TSB. It should be a while when I need a new set of rear disc pads.
  11. #71
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    You should be good for a long while... I was at around 5mm left. I could have gone longer but felt good it is all replaced.
  12. #72
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    Here are those grease instructions that came with OEM pads.
  13. #73
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,298
    Thanks for posting!
  14. #74
    Registered Member
    2016 Mazda, CX-5 GT
    Join Date
    Dec 2013
    Location
    Magnolia TX
    Posts
    93
    79,000. The rears had made 10% life left max. The fronts probably at least 30%. I drive 75% highway so that helps too.
  15. #75
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,763
    Ha ha, here in LA the freeway driving is stop and go and better in the city.
Similar Threads
  1. Replies: 30
    Last Post: 11-17-2013, 12:27 PM
  2. Replies: 25
    Last Post: 10-06-2012, 07:46 PM
  3. How Long Have Your Brake Pads Lasted?
    By Hazenvagen in forum CX-9 Wheels, Tires, Brakes & Suspension
    Last Post: 05-30-2010, 03:50 PM
  4. Replies: 10
    Last Post: 10-02-2008, 12:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
