Page 3 of 9 FirstFirst 12345 ... LastLast
Results 31 to 45 of 131
Thread: How long did your brake pads last?
  1. #31
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    I'm at shy of 41k miles.
    '15 CX-5 GT 2.5L w/tech package - 53K Miles - https://www.oemvehicleparts.com/ (30% off "shipping" with code "MAZDAS247")
  2. #32
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,475
    My stepdaughter has 70k miles on her front brakes with her 2014 cx5, got her rear brakes changed at 35k. My fronts on my 2014 had some pad left when I took them out at 60k, also changed my rears at 32k.
  3. #33
    Gen-1 Kodo Design 👌 ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,389
    Rears needed to be replaced at around 53k-54k (dont recall exactly) miles.
    I'm at 63k now and fronts are still fine.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 87k miles
    01/2013 build | 4/20/2013 delivery
  4. #34
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    8,040
    Quote Originally Posted by katmar View Post
    How long did your front and rear brake pads last? Just curious what the average experience is, and what to expect.
    My rear pads were just replaced at 33,000 miles (worn to the point of squealing when backing up), which seems early to me. I showed them the TSB about the rears binding and causing premature wear, but they claimed the wear pattern didn't match the TSB.
    My front pads were down to 5/10 (which was fine), but I replaced them anyway because for some reason my front rotors were badly gouged (saw them, they really were) and had to be replaced.
    Just curious if this is what I can expect to be doing every 33,000 miles?
    Any guesses as to why both front rotors were gouged even though the pads were only 1/2 worn? Road salt from the winter not being washed out often enough maybe?
    79k miles now. My rear pads are down to 3mm, but have been measuring 3mm for the last 10k+ miles. Dunno when it will die and need replacing, but not yet.
    I believe front are 5 or 6mm. Front rotors are badly warped though. A couple of repeated stops and the wheel is shaking.
  5. #35
    Structural Member shadonoz's Avatar
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    State of Jefferson - SO Oregon
    Posts
    2,637
    I'm surprised so many rear brakes are wearing out before the fronts. I always thought that the fronts work harder, therefore wear out faster, due to weight transfer and greater weight on the front axle. Remember when cars had discs on the front and drums on the rear? And they often [usually?] have larger discs in front than back [but only 0.2" difference on CX-5, larger in the back].
    Does anyone know why this is happening? Force distribution maybe, but why? There should normally be LESS force applied to the rears, no?
  6. #36
    Registered Member Anchorman's Avatar
    2019 CX-5 GT 184 2.2 diesel auto - Sonic Silver
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,624
    Quote Originally Posted by shadonoz View Post
    Yes, quite right. On a one for one basis (considering only the size of the pads and the design forces of the calipers), the pads should wear out evenly. However, as the weight during a stop is always transferred to the front and that is constantly variable, the fronts get hotter and they wear out quicker. How fast the friction material wears is directly apportioned to heat and it is a non linear relationship, in other words, what ever the wear is at 300F isn’t doubled at 600F, it might be tripled or quadrupled. Pads need heat to make them work properly so low duty will make them sleep and high duty will excite them and make them perform best but wear quicker. Friction has nothing to do with area so you could literally cut an inch off each end of the pad and they will work exactly the same (more pressure per unit of area) but they will get hotter and in that case wear quicker.
    So back to the original question. If the rears wear quicker, it could be that the vehicle often has weight in the rear, the fronts aren’t doing what they should (maybe need servicing) and therefor push the work done to the rear or something is causing the rears to get hotter than they should like the calipers sticking slightly and they are dragging. There isn’t necessarily a fault though. It might be that the rear calipers have a lower threshold than the fronts (this is the amount of fluid pressure actually needed to bring the pads in contact with the disc) and they just apply marginally quicker but balance under heavier load. There may be slight differences on the pad compound (friction level). There is also a solid disc which may run slightly hotter than the vented one at the front - remember the fundamentals - the hotter the friction material, the quicker it wears. You can buy these point and read digital thermometers real cheap theses days that can tell the tale and they are very good for fault finding.
  7. #37
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    8,040
    My bet is it's part of the stability control. The rears get used far more than you think. Just a guess.
  8. #38
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    I think stability control as well and/or the EBD. My Infiniti wears more on the rear as well.
  9. #39
    Donated: $5
    2017 CX-5 GT AWD PP
    Join Date
    Oct 2017
    Location
    Posts
    2,637
    Quote Originally Posted by Unobtanium View Post
    That's a good bet, I'll bet.
    Quote Originally Posted by Anchorman View Post
    OK then, too many variables to generalize. That would also account for the minority reporting faster wear on the fronts.
  10. #40
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,831
    Blog Entries
    6
    I'm gonna throw a new hardware kit on the rear as well. OEM only about $14
    PN: K0Y12649ZA ('13-'15)
  11. #41
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    8,040
    I'd bet they take corners more sedately or live in flat areas. I know the cx5 has a very high threshold of "behind the scenes work" before anything illuminates on the dash regarding the various stability processes, and that we are provoking them a lot more than we think we are.
  12. #42
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,306
    Arrow How long did your brake pads last?
    My theory is most late model vehicles are "designed" to wear out rear brakes faster. Earlier vehicles were having larger brakes at front and smaller brakes at rear due to the reason you described. Newer vehicles use EBD applying rear brakes more for light braking situation. But auto-makers don't want to put larger brakes at rear to extend the life-span due to mainly cost issue or sometimes the space limitation with parking brakes there. Small disc pads with more usage will make the life shorter. Hence we'll see much shorter rear pad life-span on many new vehicles.
    For our Mazda CX-5 there're some rust issues and lack of lubricant issues on caliper pins which contribute early replacement on rear pads. For some early CX-5 with new EPB there's issues on original rear calipers which can't release EPB properly and causes uneven and faster wear-out on rear pads.
    My 2001.5 VW Passat needed new set of rear brake pads and rotors at 45K miles while the front still had about 70% of pad's life left. On the the other hand my 2000 BMW 528i needed new set of front brake pads and rotors at 45K miles but the rear is still fine at current 61K miles. Of course BMW has dedicated small drum brakes at rear used only for parking brake which should prolong the rear pad's life.
    Then my 1998 Honda CR-V at 180,738 miles has gone through 3 sets of front pads, but the rear brake shoes are still original from factory! (boom03)
  13. #43
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,763
    That is, what I knew as well, the electronic brake distribution is shifting the braking power to the back, this way the car does not dip at the front, in case of a hard brake. It is safer.
  14. #44
    Registered Member Lbear's Avatar
    2017 CX5 AWD Touring
    Join Date
    Oct 2008
    Posts
    919
    I believe the brake pad issues were addressed and fixed for the 2017+ models
  15. #45
    Registered Member gdluke's Avatar
    2018 Mazda CX-5
    Join Date
    Mar 2018
    Location
    Sacramento, CA
    Posts
    91
    [QUOTE=Kedis82ZE8;6583721]I'm gonna throw a new hardware kit on the rear as well. OEM only about $14
    Great idea! I've found that the hardware keeps the brakes from squeaking and sliding around. I learned from experience that the hardware is only good per each set, or else the stuff gets loose.
Similar Threads
  1. Replies: 30
    Last Post: 11-17-2013, 12:27 PM
  2. Replies: 25
    Last Post: 10-06-2012, 07:46 PM
  3. How Long Have Your Brake Pads Lasted?
    By Hazenvagen in forum CX-9 Wheels, Tires, Brakes & Suspension
    Last Post: 05-30-2010, 03:50 PM
  4. Replies: 10
    Last Post: 10-02-2008, 12:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
