IAmSupernova
- Protege5
Car ran just fine the day before yesterday. No problem at all starting. I was working on it yesterday (nothing that would cause it to not start, was messing with the VTCS and o2 sensor) and when I went to start it, it wouldn't turn over so I checked the battery and it had a low voltage (around 10v). The battery is old and probably needs to be replaced, but decided to have AutoZone check it out and they said it seems fine. They charged it up and I came home and installed it, car turned over just fine, but it will not start now. Did some Googling and tried a couple of different things. I cannot find an alarm override switch (I'm not sure if this car even has one) but I repeatedly unlocked the driver side door with the key and I also shifted between park and drive back and fourth a bit. Neither made the car start.
Any ideas on why it wouldn't start after the only real thing I've done is disconnect the battery? Could it still be the battery even though they said it held the proper charge fine and has no problem turning over the engine for an extended period of time?
