http://oemdtc.com/21965/check-engin...0301-p0302-p0303-andor-p0304-2012-2013-mazda3Carbon may be deposited around the intake valves, resulting in unstable engine combustion and misfiring during the accelerated warm-up system (AWS) operation.
oh oh...
Well, there goes the argument that there are no documented cases of carbon build up on skyactiv engines..
Wonder which procedure they use
Not so fast, amigo. We are not discussing all Skyactiv engines here and the most important difference between the 2.0L in the Mazda 3 and the 2.0L and 2.5L CX-5 engines is that the Mazda 3 did not have the physical space in the engine bay to use the 4-2-1 Skyactiv scavenging header exhaust.
The function of the extra long 4-2-1 scavenging header is to scavenge exhaust gases from the manifold so they cannot go back into the cylinder. During fully warmed up operation this can cause hot spots (heated by the exhaust gases backing up) and during cold starts it can cause deposits.
This is not evidence the CX-5 is susceptible to this (and even if it were, venting the crankcase to the atmosphere wouldn't do a thing to alleviate it).
All the skyactiv engines are very similar. If one has the problem it's a far stretch to think that the others are immune to it because of the 4-2-1 exhaust header.
I do agree that venting the crankcase to the atmosphere most likely won't solve anything.
Does anyone even know if the Skyactiv engines have an EGR valve? With advanced variable valve timing it may not even be needed or even work with such a low pressure exhaust header. The whole purpose of the EGR valve back in its heyday was to help cool the combustion process with inert gasses and thus reduce NOX emissions.
Does anyone even know if the Skyactiv engines have an EGR valve? ...
It would also have to grant the propositions that 1)there IS carbon buildup on the latest generation 2.0 and 2.5 SA-G engines and 2) the vent gasses indeed are the source of the carbon for that build-up, both very much uncertain for the time being.
This is the part that has me wondering what the concern is with carbon build-up. They are designed to go hundreds of thousands of miles without de-carbonization necessary. And in light of no evidence to the contrary, why is this even a concern?
It would be like purchasing a new pair of brand X jeans and immediately triple-stitching the crotch to prevent blow-out, even though there were no reports from others that brand X jeans were blowing out at the crotch.
It's baffling.
If the others meet the requirement with no measurable penalty, then why all the fuss?
It's baffling.
I should also point out that there is not a single documented case of excessive carbon on the valves of a Skyactiv GDI engine. At least not a stock engine. Start messing with various tuning parameters and/or breather hoses/valves then all bets are off.
In other words, there is no reason to worry about carbon build-up on the valves.
That's nice to know. This is my first GDI engine and I'm glad I waited a bit for the technology to mature.
I think you've missed a few key points: the SkyActiv engine merely uses GDI as one component of a whole host of technical enhancements many which, whether by design or serendipity, overcome limitations imposed by others. Each of them individually may be pretty mature (even Atkinson cycle which has been used over a decade in hybrids) but I don't think I'm wrong in saying Mazda's application of everything is itself at least fairly novel in production automobile engines.
And of course it's obvious why: mfr's have to develop means to meet ever tighter emission and fuel economy regulations. Others are using tiny motors and turbo's; Mazda is using SkyActiv.
The upshot of all this is it's actually very new technology.
I think Mazda used Atkinson Cycle engine back in the mid '90s in the Millenia sedan
