Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 112
Thread: Rear Diff and Transfer Case Fluid Change: tools parts and links
  1. #46
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,423
    Blog Entries
    8
    I changed mine after vehicle sat in the garage overnight.
    NB1 Navigation Updates (1005 NEW-2/2018) / Why Mazda moly oil? - Mazda TSBs / Mazda owners manuals / SkyActiv Oil Analysis Thread
    Current Vehicles:
    • '15 CX-5 GT 2.5L w/tech package & i-ACTIV AWD - Liquid Silver Metallic (04/2014 build-07/2014 delivery) - 41K Miles
    • '12 Lexus GX 460 Premium (Toyota Land Cruiser Prado Kakadu 150) BOF / Torsen with ATRAC AWD/MTS/Crawl Control - 47K miles
    • '07 Infiniti G35x w/tech (Nissan Skyline V36) / ATTESA E-TS AWD - 94K miles
    • '00 Jeep Wrangler 4.0L TJ - 5 speed / NP231 PT Transfer Case - 118K miles
  2. #47
    Registered Member Lbear's Avatar
    2017 CX5 AWD Touring
    Join Date
    Oct 2008
    Posts
    791
    I changed the front and rear differentials AWD (6,500 miles)
    The rear differential was tightened by some gorilla because it was tough to break the plugs. Finally did it and drained it. There was about 1/4 inch of metal shavings on the magnet and the fluid was nasty. When clutch plates break-in, they release tons of debris before they get their mating and wear in pattern. I'm glad I changed the fluid.
    The front differential was a lot easier to remove the plugs BUT the drain plug didn't tighten down with the torque wrench properly and left me uneasy. I think they over tightened it at the factory or the threads were not properly cut at the factory. So I put down about 2 wraps of TEFLON TAPE on the bottom drain plug. I hand tightened it with a 3/8" drive until it felt tight and took it for a spin. No drips, no leaks. The front differential drain plug faces straight down.
    The rear plugs were torqued to 30ftlbs and the fronts were tightened with a 3/8" drive to snug.
    Here if the fluid at 6,500 miles:
    This is what the new fluid looks like:
  3. #48
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,423
    Blog Entries
    8
    i feel lot better about having changed mine too. I plan to change AT fluid before 30K miles... still need to order that fluid and find a weekend with some time.
    EDIT: I am glad this entire driveline is fairly easy to maintain. I cringe at what the '07-'15 AWD CX-9 owners have to go through to maintain the "lifetime" fluid in their transfer case.
  4. #49
    Join Date
    Oct 2008
    Posts
    791
    Quote Originally Posted by Kedis82ZE8 View Post
    I might do the transmission a little earlier than that. Maybe around 15k miles. There is usually a lot of break-in clutch material on new transmissions, just like differentials.
  5. #50
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    5,933
    Arrow Rear Diff and Transfer Case Fluid Change: tools parts and links
    Quote Originally Posted by CX5-SO View Post
    Genuine Mazda Fluid (0000-77-80W9-QT) SAE 80W-90 Rear Differential Oil - 1 Quart
    http://www.amazon.com/Genuine-Mazda-...s=mazda+80w-90
    According to owner's manual, both front transfer case and rear differential use Mazda Long Life Hypoid Gear Oil SG1, part no. 0000-77-SG1-QT, with list price $29.95 per quart:
    OP used different Mazda gear lubricant, Mazda Premium Rear Axle Lubricant SAE 80W-90, part no. 0000-77-80W9-QT, with much lower price:
    I think I'd use Mazda Long Life Hypoid Gear Oil SG1 when the time comes.
  6. #51
    CX-5 SPOUSE CX5-SO's Avatar
    2013 CX-5 Touring AWD A-T
    Join Date
    Jul 2012
    Location
    Appalachiastan
    Posts
    116
    As stated in manuals.
  7. #52
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    5,933
    Thanks for the clarification. So Mazda changed recommended gear lubricant for its AWD system although the system is the same through all model years. Since Mazda Long Life Hypoid Gear Oil SG1 recommended now is almost 3 times more expensive than Mazda Premium Rear Axle Lubricant SAE 80W-90, I'd say something must be added to it for better performance or longivaty to Mazda's AWD system. It only takes a quart for the change, I'd definitely go with new and more expensive Mazda Long Life Hypoid Gear Oil SG1. Wonder what gear lub did Lbear use for his 2016 CX-5?
    OP, it'd be nice to add this spec change image in your original post to prevent the confusion on gear lubricant, as many members here will use your post for reference ordering tools and parts like I did. And again thanks for the very helpful info!
  8. #53
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,423
    Blog Entries
    8
    I used Amsoil in mine. No concern about lubricating qualities. Perhaps I will lose some .x on the MPG but not gonna sweat it. I've said this before but on rear diff... rear fluid was not at fill line on stock fill. I put in more fluid than what came out. A few others who changed said the same. FSM states to fill line for proper level.
    EDIT: I plan to change every 20-25K miles so long life fluid does not really blend in with my maintenance schedule. Transfer case oil quantity was seemingly spot on though.
  9. #54
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    5,933
    For your 2015 CX-5 AWD, does the owner's manual specify gear lubricant for transfer case and rear differential the same as 2013's or 2016's? And are you saying the rear differential needs more than factory specified 0.48 US quarts to fill up to the filler hole? So one quart of gear lubricant may not be enough for the lub change for both?
    CX5-SO, thanks for adding the specs!
  10. #55
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,423
    Blog Entries
    8
    Mine is same as 2013. Correct. I needed more than one quart to change both. Front was seemingly spot on... rear needed more than half quart. Unfortunately I didn't measure. I don't think 3/4 quart but it seemed around or shy of 2/3 quart was what it took.
    EDIT: Vehicle was cold and level.
  11. #56
    Donated: $8
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    5,933
    Very appreciated for your info! Otherwise for $30 a quart, I'd just get a bottle of Mazda Long Life Hypoid Gear Oil SG1 thinking it should be enough for 0.48 US quarts X 2 but ended up I've to get more during the change! Not good!
  12. #57
    Registered Member
    CX 5 Grand Touring / AWD Tech package
    Join Date
    Apr 2015
    Location
    West Virginia, US
    Posts
    99
    Any idea how much dealers charge for this service?
  13. #58
    Registrierte Benutzer Chris_Top_Her's Avatar
    Donated: $40
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    5,416
    I think I paid 80 with materials the first time I ever had it done
  14. #59
    zoom zoom runtohell121's Avatar
    2014 Mazda CX-5 Touring AWD Soul Red
    Join Date
    Jul 2013
    Location
    California
    Posts
    464
    When changing the differential fluid... Do you just add/pump in the fluid until it leaks? Or is there a way to measure how much fluid should be added into the differential? Planning to do the differential fluid change soon.
  15. #60
    Registered Member Conrad 16.5's Avatar
    2016.5 CX-5 Grand Touring AWD titanium/black
    Join Date
    Sep 2016
    Location
    Northern Illinois
    Posts
    732
    Quote Originally Posted by runtohell121 View Post
    Just fill it till the oil starts dribbling out of the fill hole. Allow it to drip till it stops then put the filler plug in and away you go.
    FYI, Mazdastuff.com has the SG1 for $21.56
    "Don't bother me with facts, Son. I've already made up my mind." -Foghorn Leghorn
Similar Threads
  1. Anyone change fluid in transfer case on an AWD CX-5?
    By Kedis82ZE8 in forum CX-5 Engine & Transmission
    Last Post: 09-25-2016, 12:23 PM
  2. 2013 CX-9 AWD - Transfer Case Fluid Change...Attempt
    By msujay2012 in forum CX-9 Engine & Transmission
    Last Post: 01-20-2016, 02:55 AM
  3. Needs help with Transfer case fluid change
    By dapple08 in forum CX-9 Lounge
    Last Post: 10-04-2015, 10:26 AM
  4. Fluid Maintenance Transfer-case beware
    By KrisKringle in forum CX-9 Engine & Transmission
    Last Post: 04-27-2015, 02:42 PM
  5. Rear diff fluid change?
    By phoned in forum CX-5 How-To
    Last Post: 07-06-2014, 04:56 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
