Your Best Source for Genuine Mazda Parts!
Page 1 of 8 123 ... LastLast
Results 1 to 15 of 112
Thread: Rear Diff and Transfer Case Fluid Change: tools parts and links
  1. #1
    CX-5 SPOUSE CX5-SO's Avatar
    2013 CX-5 Touring AWD A-T
    Join Date
    Jul 2012
    Location
    Appalachiastan
    Posts
    116
    Exclamation Rear Diff and Transfer Case Fluid Change: tools parts and links
    I have coming from Amazon
    OEM Tools 22297 23mm Metric Socket (THIS IS A VERY SHALLOW SOCKET)
    http://www.amazon.com/OEM-Tools-2229...89%3AOEM+Tools
    OEM Tools 22298 24mm Metric Socket (THIS IS A VERY SHALLOW SOCKET)
    http://www.amazon.com/OEM-Tools-2229...+metric+socket
    Genuine Mazda Fluid (0000-77-80W9-QT) SAE 80W-90 Rear Differential Oil - 1 Quart
    http://www.amazon.com/Genuine-Mazda-...s=mazda+80w-90
    I have coming from arlingtonmazda.com
    DRAIN PLUG WASHER (ISH9956-41-800)
    http://parts.arlingtonmazda.com/prod...52d800%29.html
    Thanks go out for the member that gave the plug head sizes!
    EDIT: 07-11-2016
    MAZDA HAS CHANGED THE SPEC ON THESE FLUIDS FOR LATER YEAR MODELS. CHECK YOU OWN OWNER MANUAL FOR THE RECOMMENDED LUBE FOR YOUR CX-5.
    EXAMPLE DIFF. BETWEEN 2013 AND 2016 YMs
  2. #2
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,333
    Blog Entries
    8
    Quote Originally Posted by CX5-SO View Post
    I'll probably pick up new drain washers next time I change it. Good list of items for those who don't have the needed tools.
    NB1 Navigation Updates (1000 NEW-11/2017) / Why Mazda moly oil? - Mazda TSBs / Mazda owners manuals / SkyActiv Oil Analysis Thread
    Current Vehicles:
    '15 CX-5 GT 2.5L w/tech package & i-ACTIV AWD - Liquid Silver Metallic (04/2014 build-07/2014 delivery) - 38K Miles
    '12 Lexus GX 460 Premium (Toyota Land Cruiser Prado Kakadu 150) Body-On-Frame/ Torsen with ATRAC AWD - 42K miles
    '07 Infiniti G35x w/tech (Nissan Skyline V36) / ATTESA E-TS AWD - 91K miles
    '00 Jeep Wrangler 4.0L TJ - 5 speed / NP231 PT Transfer Case - 115K miles
  3. #3
    Registered Member gova's Avatar
    '14.5 CX-5 Touring AWD, Soul Red | '14 CX-5 Touring AWD White
    Join Date
    Jul 2012
    Location
    IL
    Posts
    477
    Do you need a pump?
    How much fluid for each - front and rear should get exchanged?
    Are rear diff and xfer case conected (same oil) or each is separate?
  4. #4
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,333
    Blog Entries
    8
    I normally use a hand pump like one of these when changing diff or transfer case fluids.
  5. #5
    Registered Member GP 2004's Avatar
    2015 CX-5 GT AWD liquid silver
    Join Date
    Dec 2014
    Location
    Chicago suburb
    Posts
    574
    Good to know. Thanks for posting.
  6. #6
    Registered Member
    2014 Mazda3
    Join Date
    Aug 2015
    Location
    Southwest
    Posts
    220
    Quote Originally Posted by gova View Post
    Do you need a pump?
    Good question...
    Also, is the fluid synthetic?
  7. #7
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,333
    Blog Entries
    8
    Quote Originally Posted by littlebear View Post
    Good question...
    I would definitely use synthetic.
    I plan to use this.
    More info in this thread
    http://www.mazdas247.com/forum/showt...erential-fluid
    Specs say around .5 quart but can't remember if anyone said it is actually more to bring up to fill line.
  8. #8
    Join Date
    Jul 2012
    Location
    Appalachiastan
    Posts
    116
    Done
    The Wife's turned over 30k and I had a couple days off from work, so, the fluids got a change.
    I made extenders from 2x10s and 1/2" by 4" carriage bolts so I could easily get 'er up and level on my 4 Rhino Ramps. The extenders are gotten out of the way by simply lifting them up and out of the ramps.
    I got the idea from this YouTube video: https://www.youtube.com/watch?v=DSH8shmHvgg
    The low angle provided by the extenders made it super easy for the CX 5 to crawl to the top.
    I got these snapshots off my security camera.
    The changes went off without a hitch. Getting the splash shield off was the hardest part. The sockets I bought worked perfect and were shallow enough that I was able to use my 3/8 drive torque wrench in the tightest spot, which ended up being the rear diff. fill plug. For the diff. change, you will be working very close to the exhaust, so, maybe let things cool off for a period before you start.
    One last note, the diff. fluid came out pretty darn clean, much more clear than I expected. The transfer fluid was somewhat dark but nothing out of the ordinary. Both drain plugs had just a tiny amount of metal captured.
  9. #9
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    5,384
    Arrow Rear Diff and Transfer Case Fluid Change: tools parts and links
    I like this idea too and will do the same when it's my time to do the change. Thanks for the helpful info and links!
  10. #10
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,333
    Blog Entries
    8
    CX5-SO: Was drained fluid less than what you put back in? Was level up to the fill hole before you drained it?
  11. #11
    Join Date
    Jul 2012
    Location
    Appalachiastan
    Posts
    116
    Drained fluid was less and factory level was not up to the fill hole. I filled as I have always done, pumped until I saw fluid draining back out the fill hole and then let it sit until there was not even a drip coming out. I figure there are always air bubbles to come to the top and nicks and crannies to be filled, so by filling until overflow, the fluid should settle down to just about right. The wife took the vehicle on two trips after the change, totalling 685 miles, without issue. I am going to say that filling to the bottom of the fill hole is perfectly fine in these vehicles, but that is just my opinion. Others, please do what makes you feel good, I'm not a Mazda engineer.
  12. #12
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,333
    Blog Entries
    8
    +1 On filling to the bottom of the fill hole. That is what I intend to do and what I have done on other vehicles and powersports equipment like ATVs.
  13. #13
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,333
    Blog Entries
    8
    CX5-SO: Did you note how much fluid you used between front and back? 2 quarts sufficient? I know what FSM says but to bottom of fill line might be more. Thanks!
  14. #14
    Registrierte Benutzer Chris_Top_Her's Avatar
    Donated: $40
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    5,192
    Im doing mine right now. The front is draining. So far the top plug had no oil on it. The drain plug was covered in sludge. 28000 mi since purchased in sep 2014.
  15. #15
    Join Date
    Jul 2012
    Location
    Appalachiastan
    Posts
    116
    Quote Originally Posted by Kedis82ZE8 View Post
    Yep, you will need 2 quarts to have enough to go to the bottom of the fill hole on both and allow some for the overfill runout. I just ran out to the garage and checked the 2 bottles I used. It looks like I used a total of about 36 ounces, so that is not much over the .48 qt for each that is stated, but it's enough to warrant the 2 bottle purchase. Plus, the next change will only require a 1 qt purchase to complete the job.
Similar Threads
  1. Anyone change fluid in transfer case on an AWD CX-5?
    By Kedis82ZE8 in forum CX-5 Engine & Transmission
    Last Post: 09-25-2016, 01:23 PM
  2. 2013 CX-9 AWD - Transfer Case Fluid Change...Attempt
    By msujay2012 in forum CX-9 Engine & Transmission
    Last Post: 01-20-2016, 03:55 AM
  3. Needs help with Transfer case fluid change
    By dapple08 in forum CX-9 Lounge
    Last Post: 10-04-2015, 11:26 AM
  4. Fluid Maintenance Transfer-case beware
    By KrisKringle in forum CX-9 Engine & Transmission
    Last Post: 04-27-2015, 03:42 PM
  5. Rear diff fluid change?
    By phoned in forum CX-5 How-To
    Last Post: 07-06-2014, 05:56 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
