Fluid leaking from passenger side.
Targaryen420
2002 Mazda Protege5
So i got home after running some erronds and i found that some kind of fluid is leaking. It was greenish clear from what it looked like, which might mean my coolant? I checked my coolant and it doesnt seem to be leaking.
Any ideas?
If you look at the passenger side wheel, its right underneath. it was dripping from two spots, and couldnt get fully underneath to see, and couldnt see any problems from the top.
Do you have green windshield wiper fluid? I use green Rain-x.
That's in the vicinity of the water pump.
They have a weep hole that will drip when the internal seal fails. The bearings will be soon to follow since they are contaminated with coolant.
Taste it... If it's sweet it's antifreeze...
Spit it out though, too much will kill you...
