as stated in title my rear tires have heel and toe wear (or a few flat spots) i recently purchased this car and so i do not know all its history, i do not think the prior owner rotated the tires much, if at all. when i got the rears rotated to the front i noticed a vibration afterword so i went back today and they found the heel toe wear issue on the ones that had been on the rear when i purchased the car. they balanced the vibration out, for the most part. however they are the exact brand and tire model i hated on my protege 5 (granted this car is heavier and has 17 inch tires where as protege 5 had 16) so they dont seem as squirrely under the car but i still think they are too hard for good handling and sporty feel like i like (they are yokohama yk580s) the tire guys showed me it was not severe yet however it will not "just wear out of the tire" or not for a long time anyway (it appears to run through at least a few 32nds of the tread) the tires are at about 7-8ish 32nds wear and the ones on the front had some inner and outer shoulder wear (as to be expected when not rotated) the alignment is good and it tracks straight
my question is should i get a new set of tires? (all 4) i do not like buying in pairs as i dont like mismatched tread even if all 4 tires are of same brand and model
and are bfgoodrich g-force comp2 a/s good tires to get if i should get new tires (if you have experience with them)
