New Product Release!! 2006-2013 MS3/6 & CX7 EGR Valve Delete Kit!
JBR
Authorized Vendor
09' & 2011 MazdaSpeed3
Details:
The JBR EGR valve Delete Kit removes the entire EGR valve resulting in more horsepower and keeping carbon and soot build up from occurring in your DISI engine.
The EGR System recirculates dirty, hot exhaust gasses back into the intake resulting in a significant build up of carbon deposits on the valves. This build up will eventually lead to a loss of compression, loss of horsepower and ultimately leading to costly and time-consuming repairs to correct the problem.
By adding the *JBR EGR Valve Delete Kit and removing the EGR valve, horsepower is increased! Cooler, denser air makes more power and recirculating hot exhaust gasses back into the intake is robbing you of that power! Removing the valve also increases the space needed for going big turbo plus, it really makes for a clean looking engine build. Our EGR Valve Delete Plate is CNC machined from 1/2" 6061 aluminum and includes a brass coolant line fitting, a 304 stainless plug and all the necessary mounting hardware.
Achieve the highest level of protection against carbon and soot build on your valves up by pairing the JBR EGR Valve Delete Kit with one of our Oil Catch Can Kits.
Application:
2006 2013 Mazdaspeed 3/6 and CX7
Features:
  • Designed, Engineered and Manufactured in the USA
  • Black anodized finish for long-lasting corrosion-free protection
  • Increases space for larger turbos - Simple bolt on kit
JBR EGR Block Off Kit Includes:
  • EGR valve delete plate
  • Coolant line fitting
  • Coolant line plug
  • 2, 8mm x 1.25mm bolts
  • 2, 8mm lock washers
  • 1, clamp
  • Installation instructions are available in our support section
  • Shipping is free in the US & our Hassle Free Lifetime Warranty is included
*There is a possibility of an intermittent CEL from bypassing the EGR system. This will not effect engine performance or longevity. The CEL can be easily cleared with a scan tool such as the VeraTuner or the COBB AccessPORT.
Latest posts
