Page 1 of 5 123 ... LastLast
Results 1 to 15 of 67
Thread: Anyone found an OBD2 phone app that will read transmission fluid temp?
  1. #1
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,755
    Blog Entries
    6
    '15 CX-5 GT 2.5L w/tech package - 49K Miles / '07 Infiniti G35x / '12 Lexus GX 460 / '00 Wrangler TJ 4.0L
  2. #2
    Wiggity-Wack-O-Tack njaremka's Avatar
    Donated: $0.61
    2011 MX5 GT
    Join Date
    Nov 2001
    Location
    Glastonbury, CT
    Posts
    6,896
    is there even a sensor in the transmission? if you have no sensor, then no app will help you.
    Nik
    2012 Mini S Clubman
    Previous:
    2011 Black MX-5 GT
    2001 Black Mica Protege ES 2.0
  3. #3
    Registered Member gova's Avatar
    '14.5 CX-5 Touring AWD, Soul Red | '14 CX-5 Touring AWD White
    Join Date
    Jul 2012
    Location
    IL
    Posts
    515
    Quote Originally Posted by njaremka View Post
    +1. It might not be there at all. I've used OBD DroidScan and DashCommand and have not seen this reading.
  4. #4
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,755
    Blog Entries
    6
    Reviving my old ancient thread
    FORScan Lite recommended by "yugrus". Thanks Again. Love watching the engagement ratio of the i-Activ on the rear end.
    In addition to AT fluid temp you can see rear diff temp as well.
    I was pulling my boat today over the pass and pushed it pretty hard. The difference in temp between coolant and AT was about 15-20 degrees at the hardest. AT got up to around 211 degrees F while Coolant was around 192.
  5. #5
    Registered Member BlkDakDave's Avatar
    Mazda CX-5 Touring 2016.5
    Join Date
    Jul 2018
    Location
    TX
    Posts
    35
    I have a Tacoma and use Torque Pro on my android phone. I got the OBD 2 and the app to assist with the changing of the automatic transmission fluid (ATF) in my truck. You see the tranny is "sealed" and there's no dip stick to check the level of the fluid. In order to properly check the level, the ATF needs to be between 115 & 130 degrees F. The first time I plugged in the OBD 2, I could not find a ATF temperature. I had to set it up the software with a PID code in that would tell the OBD to read the ATF temp. I went on Tacoma World forum and the Torque forum and found the codes for both temperature readings, 1 - pan temp and 2 - converter temp.
    I was just about to start setting my wife's CX-5 profile up, so it'll be interesting to see what I get. I have read that by searching Ford vehicles with a similar engine might help.
    NEVER FORGET!
  6. #6
    Registered Member
    2014 Mazda CX-5
    Join Date
    Mar 2018
    Location
    NorCal
    Posts
    7
    if the PID works, can you share them?
    thank you
  7. #7
    Join Date
    Jul 2018
    Location
    TX
    Posts
    35
    Quote Originally Posted by Sachi View Post
    thank you
    If you're asking me, yes. Just remember the PID that I found and used was for my 07 Tacoma.
    Here is how I entered in Torque:
    For sensor 1 (Pan Temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 1
    Short Name:
    TFT 1
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    *F (I found a degree symbol on my phone keyboard which will replace the *)
    Equation:
    ((((E*256)+F) * (7/100) * 400)/10)
    OBD Header to use:
    left blank
    For sensor 2 (Converter outlet temp):
    OBD2 Mode and PID:
    21D9
    Long Name:
    Transmission Fluid Temperature 2
    Short Name:
    TFT 2
    Minimum Value:
    0.0
    Maximum value:
    220.0
    Scale factor:
    x1
    Unit Type:
    *F (Same here replace * with a degree symbol)
    Equation:
    ((((G*256)+H) * (7/100) * 400)/10)
    OBD Header to use:
    left blank
    Plenty of write ups on PID's over there at Tacoma World. Here's a link to one. Plus, there are many more for newer models. Let me know the pid I provided works or if you find one that does. I set up the profile (vehicle specs) on my wife's 2016 CX-5 last night, so I'm very interested what PID might work for her car.
    https://www.tacomaworld.com/threads/...9#post-4320421
  8. #8
    Registered Member
    Donated: $15
    2016.5 CX 5 Touring AWD, 2015 SCION XB
    Join Date
    Mar 2013
    Location
    ABE area, Pennsylvania, USA
    Posts
    1,388
    Quote Originally Posted by Kedis82ZE8 View Post
    What obd2 reader are you using? TorquePro reads out trans temps as well, although I thought some one on here said that the same sensor reports both(temps are the same) I'm using BAFX reader and can't get the FORScan demo app to connect
  9. #9
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,755
    Blog Entries
    6
    Just using one of these ELM 327 Wifi adapters with Forscan
    https://www.amazon.com/gp/product/B00W0SDLRY
    On the Toyota stuff.. nice thing about OBD Fusion is that it just works. No need to put in the custom PIDS. Pan and TC temp are easily obtained. Just add the gauges. I use Fusion on my GX.
    Nothing to enter for the CX-5 temps I listed above. Just add them in on Forscan Lite.
    ** What I noticed about temps was that on flat level ground the difference between coolant and AT temps was usually a few degrees. Head off to a hill towing a trailer and you will see a wide gap of 10-20 degrees. It was interesting to see how warm the rear diff gets too.
    Forscan - Android
    Forscan IOS
    OBD Fusion - Android
    OBD Fusion - IOS
  10. #10
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,755
    Blog Entries
    6
    If you were asking for Mazda PIDs... I don't see a way in Forscan to reveal them for the CX-5
    thank you
  11. #11
    Join Date
    Jul 2018
    Location
    TX
    Posts
    35
    From your post, it appears that the OBD Fusion App brings up the transmision temp (and others) for the CX-5 by adding gauges without having to do custom PID formulas. Sounds promising. Plug and play is always better than searching for a custom PID formula that works. As for the FORScan Lite App, you'd have to add the PID. Is that correct?---->Appreciate your input!
    This is the OBD2 Reader that I've had for quite a while now and use with Torque Pro for my 07 Tacoma. And yes, I had to add custom PID's for tranny temps. I've now set up the profile for my wife's CX-5 on the Torque Pro and added a transmission temp PID formual. Gonna test it out once she gets back from shopping.
  12. #12
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,755
    Blog Entries
    6
    Sorry... talking about different apps and vehicles.
    For the CX-5
    Try out Forscan Lite
    Fusion will probably work as well on CX-5 but haven't tested that out for AT temps. Pricewise Forscan will be cheaper.
  13. #13
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,755
    Blog Entries
    6
    Forscan has a free compatibility checker to see if your hardware will work with it
    https://play.google.com/store/apps/d...ch.forscandemo
    https://itunes.apple.com/us/app/fors...344642568?mt=8
  14. #14
    Donated: $25
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,755
    Blog Entries
    6
    On your Toyota... Fusion will read AT temps without any custom PIDs.
  15. #15
    Join Date
    Jul 2018
    Location
    TX
    Posts
    35
    For the CX-5
    10-4
    If the PID I've entered in my Tourque Pro app doesn't work, I'm going to get a seperate reader and the FORScan app just for her CX-5
    Thanks again!
Similar Threads
  1. Replies: 13
    Last Post: 11-13-2012, 06:09 PM
  2. Replies: 2
    Last Post: 10-10-2011, 11:15 PM
  3. Transmission temp sensor placement
    By AusOrion in forum Mazda Protege
    Last Post: 03-02-2010, 11:14 PM
  4. I Found This Interesting... Must Read
    By B16RacerN2NR in forum Mazda5 Lounge
    Last Post: 05-10-2008, 03:15 PM
  5. what does your engine temp gauge read
    By dulog in forum Mazdaspeed3
    Last Post: 11-30-2005, 09:21 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
