This is excellent! I just returned from a trip over the North Cascades and when I filled up it took 13.581 gallons (still had over 1.5 gallons left) and I traveled 517 miles for an average MPG of 38.2 mpg! That beats my previous best tank of 507 miles. This was with the OEM 17" tires at 36 psi, no engine/chassis mods, and a passenger/dog/luggage weight of about 575 lbs. over 4 steep mountain passes and full A/C until we got west of the pass. No other AWD with so much room can touch these figures.
I really like the range this car has - less time spent at the pump and more time and money left over to sample the beer along the way! The engine and transmission feel as silky smooth and solid as ever and not once did it feel underpowered on the steeper passes at 5-6000 feet. It just shifted to 4th and purred right up at 3500 rpm's with power and speed to spare. I think it's time to change the oil with about 7000 miles since the last change (24,000 total).
But these numbers are not quite accurate. Going through two 5 mile odometer check stations it's apparent the odometer is still under-reporting the actual distance traveled by .9%. That means my true distanced covered was 521.6 miles at 38.6 MPG! There was either no wind or very slight head/side winds.
Come on Ford and VW, Kia and all others, it's time to play catch-up!
