Made in USA and Free Shipping on all orders shipped inside the US.
Results 1 to 2 of 2
Thread: JBR has your MAC 35 Series 3-Port EBCS kits in stock!!
  1. #1
    Registered Member jbarone's Avatar
    Approved Merchant Member
    09' & 2011 MazdaSpeed3
    Join Date
    Aug 2009
    Location
    Troy, IL
    Posts
    1,495
    Arrow JBR has your MAC 35 Series 3-Port EBCS kits in stock!!
    Details:
    By request of the Mazdaspeed Community, JBR has put together an affordable *3-Port Electronic Boost Controller that utilizes the trusted MAC 35 series valve. No longer do you need to waste your time sourcing the valve, the fittings, the vacuum hose and the hardware separately to make up your own kit. We've done all the work for you and it's all right here in one complete kit at a very reasonable price.
    The MAC 35 series is a direct solenoid operated 3-way poppet valve. It features a short stroke solenoid, a balanced poppet and powerful return spring. These features translate into high shifting forces, fast consistent response times, and long life. This valve provides extremely fast response and very high high flow all in a surprisingly small package.
    We've made the installation as simple as possible too. It can easily be mounted in the OEM location and plugs directly in to the OEM wiring harness. With the 18" leads, it can be mounted most anywhere with the included mounting bracket, 36" of vacuum hose and mounting hardware.
    Features:
    - Designed, Engineered and Manufactured in the USA
    - Nickel plated vacuum fittings
    - Complete kit ready to install
    - OEM mounting location
    Application:
    2006 - 2013 Mazdaspeed 3/6 and CX-7
    Includes:
    -1 EBCS
    -3 1/8" NPT 90 degree vacuum fittings
    -1 1/8" NPT Plug
    -5 Zip ties
    -36" of vacuum hose
    -2 Vacuum caps
    -1 Vacuum T Connector
    -Mounting bracket
    -Mounting hardware
    -Carries MAC manufacturers warranty
    -Shipping is free in the US
    *Proper tuning is required for 3-port mode
  2. #2
    Join Date
    Aug 2009
    Location
    Troy, IL
    Posts
    1,495
    Got Boost Control Issues? You won't with this!!
Similar Threads
  1. FS: Grimspeed EBCS - MS3
    By keke in forum Completed Transactions
    Last Post: 06-24-2012, 12:45 PM
  2. extra 12v ports and usb ports ideas
    By aca2983 in forum Protege5
    Last Post: 02-18-2012, 10:10 PM
  3. Replies: 4
    Last Post: 06-15-2010, 12:21 PM
  4. (MS3) EBCs? or Hawks?
    By rjs_speed3 in forum Mazdaspeed3
    Last Post: 03-22-2008, 05:31 PM
  5. Perrin EBCS
    By ShaneG in forum Mazda How-To
    Last Post: 08-18-2006, 02:56 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
