Jackie chan
- Pro5
Awesome, are you going to paint the block? I am in the process of getting another block to build. Rather than just boosting my stock motor. Might as well do it right and shoot for some better numbers.
It's about 1k for forged internals and bearings and arp Mains. More or less.how much do you think you have in bottom end parts price wise?
i'm considering a stock build if i was gonna sell my msp.. if i keep it, id rather put strong parts in.
Sent from my HTC 10 using Tapatalk
It cost me 800 in labor on the bottom end. That included overbore alignment honing for the crank new freeze plugs washing the block balancing the entire rotating assembly balancer prank Pistons and flywheel all that stuff and getting all the clearances I did the assembly myself
Mind you I wanted the built to last a good long time does getting your Machining and getting all your tolerance is correct is very important. I found machine shops that would do it cheaper job but I didn't trust them when talking to them.It cost me 800 in labor on the bottom end. That included overbore alignment honing for the crank new freeze plugs washing the block balancing the entire rotating assembly balancer prank Pistons and flywheel all that stuff and getting all the clearances I did the assembly myself
