Page 5 of 5 FirstFirst ... 345
Results 61 to 71 of 71
Thread: Best Off-Road/Mud/Snow Tires
  1. #61
    Registered Member
    Mazda CX-5 AWD Grand Touring
    Join Date
    Apr 2016
    Location
    Los Angeles
    Posts
    67
    Quote Originally Posted by mattoak7 View Post
    Are these really +30 offset? IF so that would move the outer edge of the wheel 3.15" out away from the hug, plus another 0.5" for the wider wheel.
    It doesn't look like those are 3.5"+ farther out. They look more like -30 offset, but I could be wrong....?
    Yes they are +30. Test fitted and measured at the shop. Keep in mind that each wheel design may vary how far out they go. So a 30+ for one wheel design may not fit exactly like another with the same offset and width.
    - Rich aka SIGNAL_CX5
  2. #62
    Registered Member
    Join Date
    Apr 2016
    Location
    Los Angeles
    Posts
    67
    Quote Originally Posted by thejeans View Post
    well id be happy to help them. ive got few pics like Richness does showing the CX-5 doing some off roady things.
    and with the winter blend gas out, im down to around 23.5-24 mpg, heck that's what i used to get in my 05 mazda3, and the cx-5 is bigger, more comfortable and better when i turn off the paved road so i'm not upset buy the hit.
    the one thing i will suggest, find a wheel that is under 20 lbs, the tire is definitely heavier so getting a lighter wheel will keep the total weight close to stock, i think that's part of the reason mine isn't such a big hit.
    this is with a +35 offset, i believe you are getting +/- offset mixed up....
    im running a 17x8 +35 offset
    I agree with everything thejeans said. My wheels are 20lbs ea so the end up being 1lb less than my stock 19" wheel/tire combo.
  3. #63
    Registered Member thejeans's Avatar
    2005 Mazda3 2.3
    Join Date
    Mar 2008
    Location
    Pittsburgh, PA
    Posts
    4,815
    after this past weekend, im completely sold on the Falken AT3W's, between stream crossings, small mud holes, and driving up steep dirt/gravel roads to covered in 2-3" of fresh snow, driving out of the mountains on paved roads covered in 3-4" of fresh snow. i never felt like the car wasnt going to do what i wanted it to.
  4. #64
    Registered Member
    Join Date
    Apr 2016
    Location
    Los Angeles
    Posts
    67
    Same here.
  5. #65
    Registered Member
    Cx5
    Join Date
    Feb 2018
    Location
    Palm Springs, Ca
    Posts
    3
    Quote Originally Posted by SIGNAL_CX5 View Post
    Same here.
    Will these wild peaks fit on a stock OEM 17in wheel? Or do I need completely new wheels. I really want to give these tires a try.
  6. #66
    Registered Member
    Mazda CX-5 Grand Touring
    Join Date
    Oct 2014
    Location
    Long Beach
    Posts
    31
    They should fit 17x 7.0in-8.5in wide wheel
  7. #67
    Registered Member
    Cx5
    Join Date
    Feb 2018
    Location
    Palm Springs, Ca
    Posts
    3
    Sweet, thanks
  8. #68
    Registered Member
    Cx5
    Join Date
    Feb 2018
    Location
    Palm Springs, Ca
    Posts
    3
    Did your clearance go up with these tires?
  9. #69
    Registered Member
    Join Date
    Oct 2014
    Location
    Long Beach
    Posts
    31
    Quote Originally Posted by Manford11 View Post
    Yes they went up about 1/2 an inch.
  10. #70
    Registered Member
    Mazda CX-5
    Join Date
    Jun 2018
    Location
    Austin TX
    Posts
    2
    I have my eyes on a set of wheels that are on clearance that I really like but my only concern is the tire fitment within the wheel well. I am planning on moving to Colorado in February and I'm looking into some all terrain tires. The wheels Im thinking about getting are 17x8 with offset of +45mm while I am thinking of getting a tire size of 245/65-17. Anyone have any reccomendations regarding fit/rubbing, etc?
  11. #71
    Registered Member
    2019 CX-5 Signature; 2014 CX-9 Touring AWD
    Join Date
    Jun 2014
    Location
    Michigan
    Posts
    356
    Quote Originally Posted by C9tankaichi View Post
    You should have zero problems with that setup, other than maybe added weight.
    I'll thank you to kindly see yourself off of my lawn.
Similar Threads
  1. Replies: 14
    Last Post: 12-08-2013, 11:43 PM
  2. WTB: All season tires or snow tires for Protege 5
    By sail355 in forum Completed Transactions
    Last Post: 01-10-2011, 02:49 PM
  3. Replies: 35
    Last Post: 12-16-2007, 01:23 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
