I'm looking to buy a new CX-5. I will need to get a tow hitch receiver now or later to pull my small boat. I think the 2000lb capacity should be sufficient.
How is the OEM dealer installed hitch receiver? Does it included the installation of the wiring harness as well? And where do they put the wire? On my 2002 Tribute the wiring plug socket is conveniently located right on the side of the OEM hitch itself, there is no long wire needed. Its very neat that way. Is the CX-5 wire plug just like that, or is it a long cord that just lays around flopping around back in the cargo area and you close the hatch over the wire when you string it to your trailer?
Also Im wondering if the dealer class 1 hitch is still the same one that was used on the old Tributes. If so, I wonder if I could take it off and use it on a CX-5.
