In Memory of Member 1338
Results 1 to 6 of 6
Thread: Silentnoise713 Thread
  1. #1
    Registered Member Silentnoise713's Avatar
    2008 Mazda5 Grand Touring; 2009 Honda Fit Sport/Nav MT
    Join Date
    May 2010
    Location
    PA
    Posts
    2,615
    Hello. Using this space to document maintenance and random stuff for my reference. Please ignore this thread and do not bump.
    Been using the visitor message section under my profile but running into character limits and it is not easy to organize.
    Stuff for sale:
    YellowSpeed DPS Coilovers - cheap
    ^http://www.wingood.com/flagselect.asp
    My Thread
    ^http://www.mazdas247.com/forum/showt...oise713-Thread
  2. #2
    Join Date
    May 2010
    Location
    PA
    Posts
    2,615
    Maintenance
    Cheat Sheet
    http://www.mazdas247.com/forum/showt...eet&highlight=
    2008 Mazda5 Sport (Galaxy Gray)
    2011
    24K May Acquire car, Recaro Young Sport seat, Tint 20%
    30K Aug Valvoline 5-20 dino/Fram filter, Generic engine air filter, Fumoto drain valve, S2000 antenna
    33K Sep OEM roof rack, !CEL P0138 - Rear O2 Sensor!
    35K Nov Ford Motorcraft 5-20/Mazda filter, Convert to canister filter, Generic cabin air filter
    35K Dec Flex innovations 5pt grounding, Kumho 4X tires (Hunter GSP9700 balanced, NO TPMS rebuild!)
    2012
    36K Jan Ford Motorcraft synthetic MTF
    38K Feb Recaro Vivo seat
    40K Mar Ford Motorcraft 5-20/AutoExtra +size filter, New U-clips and nylon bolts, PIAA front wiper refills
    46K July Ford Motorcraft 5-20/Purolator filter
    46K Aug MS3 F.Caliper/Centric F.Cyro125, R.Std124/Centric pads F.Metallic, R.Ceramic/Goodridge SS lines/NAPA SB/Castrol LMA
    46K Sep Rotate tires (11K!)
    47K Oct Walker downstream O2
    50K Dec OE front washer pump, covers
    50K Dec Sold
    2008 Mazda5 Grand Touring (Copper Red)
    2013:
    55K Feb Purchased; FMC 5-30 oil/filter; Fumoto valve; S2K antenna
    57K Apr OEM Roof Rack
    58K May Amsoil ATF flush, Duralast gasket/filter
    60K Jun Convert to Canister base (new gasket); Quakerstate FS 5-30 oil/FMC filter; 3M Color Stable tint 20%, ATP charcoal cabin filter
    62K Jul MS3 RSB, MS3 Moog endlinks, MS3 Prothane bushings.
    64K Jul Magnet Bra, OEM Rack off
    65K Sep FMC 5-20 oil/filter
    66K Sep Curt hitch 11127, General Gmax AS-03 tires (hunter balanced, TPMS kit)
    2014:
    70K Jan FMC 5-20 oil/filter
    72k Mar Kirkland #34 battery, WIX engine air filter
    74K Apr Remove Magnet Bra (4/26), Xencn (Osram) H9 fogs
    75K Jun FMC 5-20 oil/filter
    77K Jul Lexol cleaner+conditioner interior
    78K Oct YellowSpeed DSP coilover, MS3 front brakes, rear brake caliper R&R, SS lines, OEM FSB bushing
    78K Nov SPC arms, hunter alignment.
    80K Dec Power Steering flush (FMC Merc V), Coolant flush ( FMC Gold premix), FMC 5-20 oil/filter, re-bleed front brakes.
    2015:
    82K Jun B&M transmission cooler + Magnafine filter
    83K Aug New OEM +12 PMM, eFocus OEM RMM + bolt, OEM TMM
    84K Sep Rebuilt YellowSpeed DSP with Eibach ERS springs + thrust sheets, alignment
    86K Dec QS FS 5-20 oil, FMC filter.
    2016:
    86K Jan Rotate tires.
    87K Jun YS F:26 R:[stock], Timken bearing (WB000028), SKF C-clip (CIR166), Beck/Arnley hub nut (1030519), R Hawk 5.0 pads, Centric Premium rotors
    90K Jul MC 5-20 oil/filter
    95K Nov MC 5-20 oil/filter
    96K Dec ATP charcoal cabin filter, NGK LTR5BI-13 spark plugs, clean EGR, clean TB, check Purge valve function, clean EVAP solenoid
    97K Jan Rotate Tires, drain/fill 3 quarts of Ford FRN5 ATF, remove ATF cooler + filter, remove YS coilover, remove MS3 RSB (no RSB)
    2017:
    100K Mar Quaker FS 5-20, MC filter, RainX beamless wipers 28"/16"
    102K May General AltiMax 215/50/17 (road force balanced, NO TPMS seal kit)
    105K Jul FMC 5-20, FMC filter
    105K Aug "cross" rotate tires
    105K Oct Install backup camera +LCD mirror, change valve cover gasket (Fel pro)
    107K Nov Install BMX Nittro 300x4 amp, InstallBay LOC, radio cubbie, hardwire Aux-in (Kevino BT)
    107K Dec Reman. Fuel Injectors (MX-5), A1 Cardone reman. throttle body, Gates idler, Gates serpentine belt
    2018:
    110K Mar QS fs O-20, FMC filter, Gates AC belt, cross rotate FL->RR, RL->FL, FR->RL, RR->FR, replacement General tire (currently on RL)
    111K May New OEM EGR Vapor purge valve solenoid (MPG increase)
    113K June Vacuum Intake Manifold Runner Control Valve Solenoid (x2 ebay), New set of Mahle injector O-rings
    114K Aug Centric rear pads (30110950 w/ hardware&bushings). HPS warranty.
    115K Oct OEM PCV valve, New Mehal injector O-rings, New Interstate group 34 battery
    116K Dec QS fs 5-20, FMC filter, rotate tires, 3 quart Valvoline ATF.
    2019:
    116K Apr Bilstein B4s front/rear, rebuild OEM strut bearing, new FRONT Genearl AltiMax 215/50/17 tires
    120K Jul Mobile1 2-20 high mileage, FMC filter, 3 quart Valvoline ATF, fix side skirt
    122K Sep Flushed 9 quart Valvoline ATF, fixed front bumper fastener
  3. #3
    Join Date
    May 2010
    Location
    PA
    Posts
    2,615
    To-Do
    Maintenance to-dos:
    Repair OEM side skirt
    Repair battery air duct
    Rust spot touch-up
    Improvement to-dos:
    DIY Softride mount/extension (Rola 59513 @ etrailers $61)
    Install phone mount
    Install speakers + subs ?
    Install paddles
  4. #4
    Join Date
    May 2010
    Location
    PA
    Posts
    2,615
    Random
    Hunter GSP9700
    Shums Auto Repair
    3600 Rhawn St, *
    (215) 856-4123 *v
    premium brake parts vendor
    https://www.topbrakes.com/c/faq
    RX8 Paddle shifter + clockspring reference
    http://www.mazda3 forums.com/showthread.php?t=395874
    Post 6 for interior pics
    http://www.mazdas247.com/forum/showt...=1#post3707688
    8" free air sub (image dynamics, jl ib4, Dayton Audio RSS210HF-4 8" Reference HF Subwoofer 4 Ohm)
    http://www.parts-express.com/pe/show...TOKEN=54370125
    Center channel speaker
    http://www.termpro.com/asp/pubs.asp?ID=115
    Brake proportioning valve + air ducts
    http://www.mazdamotorsports.com/pdfs.../08_Brakes.pdf
    LED Puddle Light
    https://www.oznium.com/led-bolt
    All About Motor Oils
    http://www. minimania.com/Motor_Oils_-_It_Is_So_Very_Misunderstood
    Ford Focus Motorcraft Oil Filter
    Std -> bigger -> biggest
    FL910S -> FL400s -> FL820S
    3 (kg / mm) = 167.992244 pounds / in
    4 (kg / mm) = 223.989658 pounds / in
    5 (kg / mm) = 279.987073 pounds / in
    6 (kg / mm) = 335.984488 pounds / in
    7 (kg / mm) = 391.981902 pounds / in
    8 (kg / mm) = 447.979317 pounds / in
    DIY Chrome
    http://www.thehogring.com/2012/10/16...c-into-chrome/
    Brake Dust Repellent
    http://brakeduststudy.blogspot.com/
    vorshlag.com camber plate
    fealsuspension.com (rebuild service $ 75 each)
    Ideas:
    3rd row slide/tilt
    relocate spare to under trunk
    sunglass/map light holder, move existing map light to 3rd row
    light on rear hatch door
    door weather seal from up-class Ford
    channel hot air to 2nd row fan vent
    2012+ dual exhaust from Mz3/Mz5
    inside hatch lock/release
    disable belt minder
    DIY splash guard
    momentary switch (N.C) for glove box light
    aluminun diamon mat
    DIY mat clip (passenger side)
    Door bumber guards as front/rear bumper guard
    metal+plastic bolt (prevent rust)
    hinge door on OE HU
    Suspension Tech Article - must read!!
    http://rqriley.com/suspensn.htm
    Silicone Hoses (Vaccum)
    http://www.mazdas peedforums.org/forum/f11/cheap-source-vacuum-hose-139954/
    .97 per foot, USA
    http://www.verociousmotorsports.com/...e-Foot?whence=
    RXduion
    http://www.rx8club .com/series-ii-interior-audio-electronics-167/rxduino-development-chat-218257/page15/
    What are the Symptoms of a Bad PCV Valve
    http://www.agcoauto.com/content/news/p2_articleid/197
    Mazda Audio Pinout
    http://www.tehnomagazin.com/Auto-rad...ctor.htm<br />
    P0841 Auto Trans Pressure Control Switch
    https://www.mazda 3forums.com/667-powertrain-2010-2013/763280-p0841-tranny-pump-shot-2.html
  5. #5
    Join Date
    May 2010
    Location
    PA
    Posts
    2,615
    Ford eFocus RMM + Bolt
    HOUSING - Ford (CM5Z-6068-A)
    $48.16
    http://www.tascaparts.com/oe-ford/cm..._str=CM5Z6068A
    LWR TRANS MOUNT BOLT - Ford (-W500545-S900)
    M12 1.75 (thread, coarse) x 70mm
    $1.32
    http://www.tascaparts.com/oe-ford/w5...tr=W500545S900
    2012 Mazda 5
    SIDE MOUNT BRKT - Mazda (BBM5-39-080B)
    $38.36
    http://www.tascaparts.com/oe-mazda/bbm539080b
    2012 Mazda 5 PMM
    SIDE MOUNT - Mazda (BBN3-39-060B)
    $85.01
    http://www.tascaparts.com/oe-mazda/b...str=BBN339060A
    2010 Mazda 5 TMM
    SIDE MOUNT - Mazda (CC29-39-070)
    $59.50
    http://www.tascaparts.com/oe-mazda/c..._str=CC2939070
    http://jamesbaroneracing.com/shop/in...age=page&id=22
    Ford 2.5 Duratec in Mz3 using Mazda PMM
    http://www.mazda3 forums.com/showthread.php?t=647562&page=9
    http://eibach.com/sites/eibach.com.m.../ERS_19_US.pdf
    page 16+ (2.5")
    page 24+ (3.0")
    http://www.pirate4x4.com/tech/billav...lovers/Part_1/
    The initial spring rate of a dual-rate system is calculated as the product of the individual spring rates divided by the sum of the individual spring rates, according to the following formula:
    Ki = (Km * Kt) / (Km + Kt)
    Where:
    Ki = Initial Spring Rate (of combined springs)
    Km = Spring Rate of Main Spring
    Kt = Spring Rate of Tender Spring
  6. #6
    Join Date
    May 2010
    Location
    PA
    Posts
    2,615
    Need 5
    http://parts.arlingtonmazda.com/prod...%252d496).html
    NUT-CLIP (BR5S-56-496)
    BR5S-56-496
    $3.80
    U Nuts:
    https://www.belmetric.com/a575l-mach...I-gaAmU58P8HAQ
    fastenal.com
    AC Compressor Clutch bearing ($25 + 10 s/h ebay)
    http://www.ebay.com/itm/AC-Compresso...item33a5045a94
    The bearing in the pulley is an NSK 32BD4718DUM3. The bearing is also "staked" in, so you would have to probable grind them out first and then push the bearing out.
    Product Model: 32BD4718DUM3 (DUM = Dust and Waterproof)
    Structure: Angular Contact Ball Bearing
    Inside Diameter: 32 mm
    Outside Diameter: 47 mm
    Thickness: 18 mm
    Precision Rating: P0 P6 P5 P4 P3 P2
    Seals Type: Open/2RS/2Z
    Material: Chrome steel (Gcr15)
    Idler Pully
    Gates 36326
    $16 @ NAPA
Similar Threads
  1. The overall mod help me out with my decision making skills thread...thread
    By my3needsaname in forum Mazda3 Accessories & Appearance
    Last Post: 09-10-2008, 01:06 AM
  2. Thread that really will outnumber our GI Thread!!
    By mixmaster_matt in forum Lounge
    Last Post: 02-06-2006, 06:46 PM
  3. Mod help.... Unlock thread or new thread?
    By GrAsShOpPeR2k in forum M247 News & Support
    Last Post: 08-16-2005, 07:03 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
