Good Luck with that! On my 2011 CX-7 I attempted to replace the driver side low beam bulb. Driver's manual instructions are not quite correct. Had to remove the wheel, and the splash panel, and still could not disengage the clip, and in the process broke the plastic housing where the clip is attached.
Now, my problem is how to remove and replace the entire headlamp assy, and either (1) buy a new one for $400-$500, or (2) try to repair the housing with epoxy. But, I need instruction on how to remove and replace the entire assembly.
Help, anyone! Thanks.
