Wheel stud extensions
IllaNoizeTV
2003 Mazdaspeed Protege
I'm looking to get 5mm or 10mm wheel spacers all around. Does anyone know what length I should get the wheel studs? Also what is the Spline diameter and thread time for our cars (MSP)?
You can get extended studs or bolt on spacers with built in studs if you go larger than 8mm. M12x1.5 thread same as all japanese-built Mazdas and many other cars. Hub bore is 67mm
if you go with a 5mm spacer, no stud replacement should be required. bigger than 10mm, would be a good idea.
