Made in USA and Free Shipping on all orders shipped inside the US.
Page 10 of 10 FirstFirst ... 8910
Results 136 to 144 of 144
Thread: Fresh Sweet Donuts Everywhere! (work log)
  1. #136
    black ops modifications.. AzteCypher's Avatar
    2001 Mazda Protege LX
    Join Date
    Oct 2004
    Location
    Allen, Texas
    Posts
    1,805
    Ah, I see it now that you pointed it out. My roof top is in worse shape thanks to the sun. Yours looks great in comparison.
  2. #137
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,180
    most likely save up for a couple more years and go get this paint job somewhere. need to do some research on paint shops.
    03 MSP, 03 P5
  3. #138
    Registered Member haze20's Avatar
    03.5 MSP Titanium, 11 EVO X WW
    Join Date
    Jan 2005
    Location
    Virginia Beach Va
    Posts
    1,465
    Quote Originally Posted by 323 View Post
    Stock or Modified does real good work. They aren't cheap though.
  4. #139
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,180
    Quote Originally Posted by haze20 View Post
    Yes yes. This I know lol
  5. #140
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,180
    went to skyline drive with a few others.
  6. #141
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,180
    looks like a water leak into the cabin that a friend helped me fix from 2010 is back. found the passenger side floorboard wet. stuffed a tshirt up in the upper right corner of the car behind the dash and it was soaked after a storm. i'll deal with it when i can deal with it :P
  7. #142
    Damian Dpwhitehead1's Avatar
    Donated: $25
    LX, MSP 1145
    Join Date
    Jan 2005
    Location
    Owings Mills, Maryland
    Posts
    9,269
    Easily remedied, I showed a “how to” so to speak on my Instagram or Exile. You can access pretty easily if you look st pics
    Be happy!
  8. #143
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,180
    thanks, I'm aware. Just busy with work and WD as you already know.
  9. #144
    Registered Member
    lolmsp
    Join Date
    Mar 2007
    Location
    757
    Posts
    5,180
    Updates for 2019 so far:
    Around Jan/Feb, my no-weld return fitting on oil pan was leaking so spent some time fixing that. Shortly after an actual oil line started leaking. I assumed my return fitting fix failed but it wasn't the case. Replaced line and went about my business.
    Using seam sealer, fixed the interior leak in the passenger floorboard. Been through plenty of heavy storms now and no more water gets into the cabin.
    In April, removed the solid rear motor mount and replaced it with the original mount filled with window weld. Got really tired of the vibrations inside of the car. It feels much better now. That journey went really well. I completed it in 4 hours start to finish without any hiccups. Surprised since I've always read many horror stories about the rear mount. Surely the car being apart recently helped tremendously.
    My P5 beater has been down for about 3 weeks so I've been dailying the MSP and the oil pressure gauge freaked out today. During my commute to work, I looked at it and gave a reading of 0psi. Anytime it's revved over 3k or so, it'll immediately jump to 50psi and then back to 0psi as the revs drop. Logic tells me mechanical issues wouldn't cause the gauge to jump from 0 to 50 in a split second. After some research, it could be a loose connection or a bad sending unit. Apparently these sending units are notorious for failing. Many have suggested to relocate the sending unit off of the block to minimize exposure to vibrations. I will be checking for loose connections first sometime next week then ordering a new sending unit if that isn't the cause.
    Edit: Driving home yesterday, noticed the gauge basically doesn't work under about 40psi lol.
    Here's a recent photo.
Similar Threads
  1. awd donuts!!!!
    By lynnriderm6 in forum Mazda6 Lounge
    Last Post: 01-19-2009, 01:16 PM
  2. WRX donuts
    By the orracle in forum Pics & Builds
    Last Post: 09-09-2004, 11:50 AM
  3. Donuts in Class
    By MarkSpark in forum Lounge
    Last Post: 01-03-2004, 04:28 AM
  4. mmm... DONUTS
    By MYE in forum Global
    Last Post: 11-03-2003, 05:48 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
