Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: Spark Plug Removal
  1. #16
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,354
    Quote Originally Posted by ruthrj View Post
    It*s well established that the NGK plugs are the OEM without the Mazda logo (down to the part number printed on them). Yrwei did a deep dive research project and somehow found out that some CX-5*s came standard with the Denso Iridium spark plugs. Those are the only two I*d consider. Anything else is a roll of the dice.
    EBay plugs are likely going to be counterfeit when the claim is OEM for a set of 4 cheaper than the going rate of 1 plug. People who installed eBay plugs over at OdyClub thinking they were OEM lost hundreds in labor when the counterfeit set caused misfires and such in under a year of use.
    I recall reading how some Tacomas' v6 engines had NGKs on one side and Densos on the other . Both are JDM oem manufacturers and should be good as long as the specs match. No issues after 35k miles on aftermarket NGK 94124 ILKAR7L11.......only issue was my plug socket kept getting removed from my extension tool. I ended up using electrical tape to tape it unto my ratchet extension.
  2. #17
    Gen-1 Kodo Design 👌 ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    5,411
    Quote Originally Posted by CX-5um View Post
    Haha, I had to do the same exact thing when I replaced my plugs.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 87k miles
    01/2013 build | 4/20/2013 delivery
  3. #18
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,377
    Quote Originally Posted by sergeyv View Post
    [emoji23] what a non sense.... keep using oem and getting ripped off instead of using good ngk or denso spark plugs.
    Sent from my iPhone using Tapatalk Pro
    That's not nonsense, its 100% from the workshop manua specifiedl values.. just because a non oem plug is gapped correctly doesn't mean it meets the same resistance (even within the same brand, you can find tests of this in many places). If you actually research the topic (instead of a denying with 0 background) you'll find that multiple plugs with different model numbers and from different manufacturers, specified for the same car can have wildly different resistances. Considering how many years and or tens of thousands of miles plugs usually last, I'd rather pay for the performance than save $20 or $30 usd every 75,000 miles. That is, unless I test s plug and its within the range the ecu is looking for. If it's not, only the standard knock sensor behinh the intake manifold is being used which isn't as precise.
  4. #19
    Registered Member
    Red 2016 CX-5 GT Teck Isense
    Join Date
    Mar 2012
    Location
    GA
    Posts
    999
    If you look at misfire/error code engine problems on this site you will find that several people solved such problems by putting the correct spark plug in due to the ion feedback system that the ECU uses...
  5. #20
    Registered Member
    CX-5 AWD GT
    Join Date
    Apr 2017
    Location
    Australia
    Posts
    107
    Spark Plug Removal
    Quote Originally Posted by Chris_Top_Her View Post
    I work as a mechanic mate, i need no research. Have been using NGK/denso for ages on brand new cars or old ones. As long as you follow the cross reference supplied by NGK / Denso. Never ever had I any issue with those spark plugs. But again, if you want to stick to the electrical numbers and facts on paper, your choice. Iíll stick to facts in everyday use and experience.
    Cheers
  6. #21
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    8,432
    Arrow Spark Plug Removal
    What Chris_Top_Her has said does have his base. OVT (OrangeVirus Tuning) had posted following comments several years ago here.
    Quote Originally Posted by OVT View Post
    Without getting into too much detail...you guys really...really..really want to use OEM plugs....
    the reason is because the ECU uses the ignition coils, which measure a resistance across the OEM plug for pre-ignition, and extremely low levels of knock retard the knock sensor cannot pick up, along with that it gives the ECU individual cylinder information, the spark plugs are actually used "as a sensor."
    How it works exactly is proprietary information that I am not willing to share, you want to use OEM plugs.
  7. #22
    Registered Member concept's Avatar
    2014 Mazda3 S GT auto, 2008 MX5 6-speed
    Join Date
    Mar 2009
    Location
    San Diego
    Posts
    1,652
    I get my sparkplugs from Rockauto.com
    In fact, I just recently replaced my Miata (with 60,000 miles on the odo) plugs with NGK Iridiums.
    Rockauto has a great selection that almost always includes OEM at discounted prices.
    Just make sure you gap them to the factory requirement.
    2014 3S GT, Deep Crystal Blue, Eibach Pro-Kit, Enkei PF01s, Koni Sports, Pirelli P ZERO ALL SEASON PLUS tires, 225/45/18
    2008 MX-5 Touring (Mazdaspeed CAI, HIDs, Progress/Koni Sports/Racing Beat sways, SST Magnaflow muffler and tips)
  8. #23
    Registered Member
    CX-5 AWD GT
    Join Date
    Apr 2017
    Location
    Australia
    Posts
    107
    Quote Originally Posted by yrwei52 View Post
    Iím not sure what the price for spark plugs is in USA but in Australia 4 genuine Spark plugs for cx5 cost you roughly $150 AUD for a set whereas I can get NGK ones for $60. You try to convince a customer to buy genuine ones. The reason they are not servicing their cars at the dealership is because of these prices. And if that tolerance number for as spark plug was very different, it would be a very known problem and NGK wouldíve made special spark plugs just for mazda. But case is that the difference is not relevant or not that far out of spec thus no issues with aftermarket plugs. And I guess chances for this to happen is probably 1 car out of 1000.
  9. #24
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,354
    If I had the OV tune then yes I'd probably get OEM plugs. Otherwise........
  10. #25
    Registered Member
    2014 Mazda CX-5 GT AWD w/Tech
    Join Date
    Aug 2013
    Location
    Bloomington, Minnesota, USA
    Posts
    600
    Zero, zero, zero issues with NKG plugs that are marked exactly the same as OEM except for the Mazda logo.
Similar Threads
  1. 2001 Protege 1.6L Spark Plug Boot Removal question.
    By bowiefan in forum Mazda Protege
    Last Post: 12-04-2013, 02:45 PM
  2. MS6 Spark Plugs & Spark Plug Gap
    By neoshade in forum Mazda6 Engine & Transmission
    Last Post: 08-22-2012, 03:53 PM
  3. Spark Plug Gap and Transmission Drain Plug
    By Matsuda03 in forum Protege5
    Last Post: 07-13-2010, 07:08 PM
  4. TMIC removal for spark plug replacement...HELP?
    By gooniac33 in forum Mazda6 Engine & Transmission
    Last Post: 03-05-2009, 01:31 AM
  5. Spark Plug Removal
    By loveindia in forum Mazda Protege
    Last Post: 09-16-2007, 07:32 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
