Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: CX-9 Water Pump Replacement
  1. #1
    Registered Member
    CX-9 AWD Touring
    Join Date
    Mar 2014
    Location
    Fond Du Lac, Wisconsin
    Posts
    13
    Does anyone have any experience with a DIY replacement of the CX-9 water pump. My CX-9 had the water pump replaced at 14K and now it's leaking again, this time out of warranty at over 80k.
    The first time the comment from the dealer was the engine had to be removed, the alldata information also says to remove the engine. I've looked at it and I'm really not seeing an issue with removing the front cover with the engine in the vehicle. It may be the motor will have to be lifted a little once the mount is removed but I'm really not seeing where the engine has to be pulled.
    I was a tech at a Mazda dealer in the early 90's so I'm pretty confident I can pull off this repair, but I thought it probably made sense to ask the question first?
    So the question is; has anyone replaced the water pump on a Cx9 3.7 V6 without pulling the engine?
    If I end up doing the repair, I'll take some pictures.
    Thanks
  2. #2
    Registered Member
    2007 Mazda CX-9 Touring
    Join Date
    Jan 2011
    Location
    new york city
    Posts
    700
    Did you ever get that water pump problem fixed? I had it replaced at almost 70k. I had an extended warranty so all i paid was 130 bucks. If you found a way that it can be done please let us know. The service manual states that the engine has to be removed.
  3. #3
    Registered Member
    mazda cx-9, lux
    Join Date
    Jan 2012
    Location
    fla
    Posts
    4
    mine is leaking now and was told 2300 from mazda to fix. they did not say they have to pull the engine, just drop the cross member and raise the motor out a little to make it a bit easier.
    they say only one day to repair so i dont think the motor comes out.
  4. #4
    Registered Member
    2009 cx9, 2.7L v6
    Join Date
    Dec 2015
    Location
    weston, florida
    Posts
    2
    I would also appreciate info on this repair. Just doesn't seem necessary to pull the engine to replace the water pump. there has got to be someone out there that has done it!, I wonder who's idea it was to put the water pump inside the engine? It teems to me that the risk and frequency of seal failure + the complexity of the repair are far greater than any advantages...???
  5. #5
    Registered Member
    2012 Mazda CX-9 Touring AWD
    Join Date
    Mar 2015
    Location
    United States
    Posts
    192
    Quote Originally Posted by motordoc View Post
    Not when you're a dealership service department making $2300 replacing a wear item....
  6. #6
    Certifiable Pootie Tang's Avatar
    Join Date
    Jan 2010
    Location
    Burritofornia
    Posts
    326
    [IMG][/IMG]
    2008 CX-9 Grand Touring, White/Sand
  7. #7
    Join Date
    Jan 2010
    Location
    Burritofornia
    Posts
    326
    It appears that Ford/Mazda intended this water pump to be a lifetime part. Not a wear item. It is really jammed away inside the heart of the powertrain. Note that the transaxle must be separated from the engine. The pump sits in there. Yikes. BIG job. Note that the water pump is not at the "front" of the engine but in the middle of the powertrain.
  8. #8
    Registered Member
    2007 Mazda CX-9 GT
    Join Date
    Dec 2015
    Location
    Layton, UT
    Posts
    11
    This sucks! I noticed a heavy antifreeze leak the other day coming from the center of my engine block, NOT from the radiator, hoses or expansion tank. It must be a bad water pump right? There is no other reason why it would be leaking from that location?? Im very disappointed in this. My CX-9 has 149,500 miles and has been meticulously maintained. Not excited about the repair bill on this one!
  9. #9
    Join Date
    Jan 2010
    Location
    Burritofornia
    Posts
    326
    Yeas, I am concerned too. Mine has 137,000 miles. I just changed the coolant which was due at 120,000. Did you replace the coolant at 120,000 miles?
  10. #10
    Join Date
    Jan 2010
    Location
    Burritofornia
    Posts
    326
    As some of you may know, the CX-9 is actually a Ford chassis and engine. The rest is Mazda. I did some searching on Ford Edge Water Pump replacement and found this:
    http://www.fordforum.com/forum/ford-...er-pump-30978/
    http://www.fordedgeforum.com/topic/11720-coolant-leak/
    http://www.flatratetech.com/communit...howtopic=31163
    http://www.consumer-action.org/index...these_products
    Looks like Mazda might cost share the repair with you. I'll keep digging.
  11. #11
    Join Date
    Jan 2010
    Location
    Burritofornia
    Posts
    326
    If this happens to me, I will certainly ask to cost share.
  12. #12
    Registered Member
    2007 Mazda CX-9 GT
    Join Date
    Dec 2015
    Location
    Layton, UT
    Posts
    11
    Quote Originally Posted by Pootie Tang View Post
    I never flushed the coolant during my ownership however according to Carfax the previous owner did it at the Mazda dealership at 100K, so it shouldn't have a problem. I just dropped it off at the dealership this morning. Their rebuttal is, "Well most other cars require a water pump replacement with the timing belt at 100K which is usually a $1500 service so its about the same as the other cars." I guess there is some validity to that, but I still don't like the idea of the entire engine & tranny being ripped and torn apart just for a water pump.. That makes me a little nervous..
  13. #13
    Registered Member
    2007 Mazda CX-9 GT
    Join Date
    Dec 2015
    Location
    Layton, UT
    Posts
    11
    If your coolant leaks into the oil and take the engine with it maybe you could ask for cost share cause that shouldn't happen.. but just a water pump replacement they would never do a cost share..
  14. #14
    Registered Member
    Join Date
    Jan 2011
    Location
    new york city
    Posts
    700
    If your engine doesn't overheat then only the waterpump has to be replaced. The invoice from the mazda dealer had it at almost 1700 dollars. Check repair pal website for an estimate and it is probably lower.
  15. #15
    Join Date
    Jan 2010
    Location
    Burritofornia
    Posts
    326
    Quote Originally Posted by swedishfella View Post
    Oh crap. Get it out of that dealer. The car doesn't use belts, it has chains which are lifetime parts. So is the pump since it is buried BETWEEN the engine and the trans but it didn't turn out that way apparently for Ford and Mazda. Those guys have no idea what they are doing apparently.
Similar Threads
  1. Water pump!!!!
    By MAZDAROGER in forum CX-9 Engine & Transmission
    Last Post: 04-24-2017, 04:02 AM
  2. Water Pump
    By Strychnine in forum Protege5
    Last Post: 06-25-2012, 05:32 PM
  3. water pump
    By twistiert in forum Mazdaspeed Protege
    Last Post: 12-09-2007, 06:09 PM
  4. 95 millenia water pump replacement
    By wilburn in forum Mazda How-To
    Last Post: 10-11-2007, 09:11 AM
  5. Water Pump
    By FreshPrince in forum Mazda Protege
    Last Post: 11-30-2004, 03:05 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
