S smetzger 03 P5 (x2), 09 Miata, 07 Mazda3, 13 Fit, 09 Ody Jan 31, 2015 #1 What is this sensor? Just above the oil filter... Its leaking oil
M MrGiggles : Protege5 Jan 31, 2015 #2 Oil pressure switch/sender. If it's leaking from the threads, remove it, clean them, and re-install with teflon tape. Last edited: Jan 31, 2015
K kms1990 Member : 2011 mazda 3 hatchback GT Feb 2, 2015 #3 oil pressure sensor, on this old of a car if its leaking just replace it its a cheap fix and you wont have to worry about taking it out later if it starts leaking again if you just clean it.
