N njaremka Wiggity-Wack-O-Tack Contributor : 2012 Mini R55 Jan 7, 2015 #2 for what its worth, mazda uses little felt pads in between the panels for vibration abatement. if you ever have to remove any of the panels, gasket sealer (RTV, i assume?) will not be a good choice.
C callphy : 03 MSP OJ Jan 23, 2015 #4 i mean the plastic panels was thinking about using the rubber like paste (left over from last valve cover gasket change) i just brought some 3/16 and 1/4 thick foam tape, hope it will absorb some of the vibration.
