Mazdas247 Mazda of the Month | November
Antoine
Administrator
Congratulations to Bonks!
Vote Now for December!
Gray Schilling
03 MSP
Suspension/Wheels/Etc:
BC Racing BR adjustable Coilovers - Extended drop series
F:11 / R:13kg/mm 152mm Swift Springs
Fly Slotted BC front camber plates
Fly Slotted Ksport rear camber plates w/ Self fabricated Spring perches and ball joint washers
Megan Racing adjustable rear links
Stop Tech stop sport front rotors
Stop tech power slot rear rotors
Hawk HPS pads
Current Wheels: Work Emotion CR-Kai 17x9 +17
Motor etc:
ETS SMIC
CorkSport Bronze oil solid shifter bushings
"Nyloil" shifter-tranny brace bushing
Turbohoses hot pipe & S.U. CAI w/ custom 1" BPV fittings
BoostSciences Reflex Diverter valve w/ 1" tubing
Split Second air/fuel controller v2
NGK copper core BKR7E Spark Plugs
Custom "Cold air box" w/ Air ram
HKS intake filter
Cat & Muffler 'delete'
Interior:
Kenwood headunit
AEM Wideband o2 sensor
NRG steering hub adapter
Custom steering wheel spacer Custom horn 'wiper'
Custom turn signal 'engager'
Sparco horn button
Custom dual gauge pod/surround (made by a Mazdas247 forum member)
One off shift boot (made by a M247 forum member)
Custom E-brake handle wrap
Grip Royal 'Royal Grain' 350mm mahogany steering wheel
Other:
Custom Retrofitted Projector headlights
Custom finished Tail lights
Custom fog deletes
CR3 'Air Diversion Panel'
Mcgarts steel black lugs
Two tone truck horns
Custom body & paint work: Front & Rear wheel arches, rear bumper, hood, front splitter, badge 'deletes' ++
* Anything marked 'custom' has been self fabricated or modified.​
Congrats on the ROM winnings with that very spicy setup.
Who's the M247 forum member that made you the Custom dual gauge pod/surround. I'm interested in acquiring one for my car.
