2007-2013 Mazdaspeed 3 and 2006-2007 Mazdaspeed 6 BeCuse Injector Seals
CorkSport
2010 Mazdaspeed 3
Authorized Vendor
All Mazdas!
Running factory power levels or seeking high HP numbers? Your fuel injectors work under extreme compression and combustion pressure. Don't let wasted power escape around that OEM excuse for a seal. Seriously, have you seen an OEM injector seal? Throw it out now. Get the Corkport seal designed to deliver every horsepower to the ground where it belongs! Our new, improved injector seals will keep you running longer and surpassing others. They are an extremely cost effective improvement, designed for 2006-2013 MZR DISI engines available in the Mazdaspeed 3 and Mazdaspeed 6.
The seals are $189.99 for the set and can be found here
-Derrick
