check your rear light assembly and wheel well liner i had a small leak from the rear light assembly, bad thing is if thats the case with yours you have to seal it upo and reseal every time you change a bulb in the assembly, i used clear silicone around the assembly and it has worked for me
What about a ring of gray rtv around all the holes where the light bolts on and where bulbs come thru and let it dry where it would be like a pliable gasket enhancer thing where you wouldn't have to reseal it every time the light was removed?
that sounds like a good idea next time i change the bulbs instead of resealing the lights i may just do that where exactly did you drill the hole? and did you coat said hole with undercoating?I was all lazy and drilled a 1/8" hole in the bottom of the puddles then hosed the area down with undercoating.
I call it fixed.
... where exactly did you drill the hole? and did you coat said hole with undercoating?
