Hey all,
Just had some used winters put on older steel rims and had an alignment done.
Seems to ride fine but now when the brakes are applied I get a pretty good shake. I'm assuming it's rotors.
A couple of things. Apparently some bolts were rusted (on the tie rod ends I think) and they used a torch to loosen them. Then did the alignment.
They also torques the lug nuts to 100 ft/lb. Is that in the ballpark? I think the P5 was 80 or something like that (but that is for the alloys).
ANyway, does anything they did sound like it would cause a very noticeable shake when the brakes are applied?
Thanks
Thanks
