davidmspdriver
- mazda mazdaspeed protege 2003.5
would it be ok if I went from 215 45 17 to a 225 45 17, would that be a problem?
i had to run spacers on mine with 225's on the rear. the rubbed my coil overs a bit. but i think there 6 mm spacers and its a really tight fit without a rolled fender. 8mm barley fit under mine with no camber so. like 2 degrees of camber and 8mm might work.
