MAF and mass air flow are the same thing, do you mean inlet air temperature?
Why are you flashing the edu?
Are conversation is spread between a couple for emails.
Yes to your question. I need both. How is $50 for the sensors?
BTW, do you use the inserts on your motor mounts
As for the front motor mount, the DEA one doesn't accept it. It's shaped a bit thicker than the OEM front motor mount.
Yeah I have a thicker front mount brand new but it won't accept the insert.
I need to replace my trans mount. The AWR doesn't work.
Any low cost sources?
