2010 CX 9, Remove Rear Bezel on Center Console
Where the rear AC controls are mounted to? if so, it clips on, open the center console, and pull gently from the edge of the bezel. I say pull gently because you dont want to pull so hard that when it comes off you rip the connectors off of the rear ac controls.
If you don't have a set already, I highly recommend a trim removal set of tools. You can get them individually for the size you're looking for or as a set. They are awesome in that you have much less risk of marring the interior (no scratch) and they have different shapes for different clips.
Here's an example:
https://www.amazon.com/dp/ (commissions earned)
I use them for everything on the car that needs some prying force. So much safer than screw drivers (no more scratches from them skipping across the surface).
As a specific answer to your question, I would guess it's clipped on, as Mazda seems to clip everything. However, if it doesn't budge, don't force it. There could be a couple screws hiding in there.
If ya post a picture of the area in question that will help.
