Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 178
Thread: Chris_Top_Her Build Thread 2
  1. #46
    Registered Member dragonteeth's Avatar
    '15 CX-5 Touring AWD w/ Bose ★
    Join Date
    Jul 2014
    Location
    Seattle, Washington
    Posts
    207
    Ah. I was referring to these:
    But from a quick Amazon search, seems it's the "hella supertones". Was there a specific size/model you used, or are they all generally universal to use?
  2. #47
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    pretty sure they are general I don't remember the specific model number
  3. #48
    Registered Member
    CX5 Touring
    Join Date
    Mar 2015
    Location
    Miami
    Posts
    41
    I think you are the only one I've seen here with so many mods, have you been sponsored yet? Also have you been in any car show events? Thanks
  4. #49
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Quote Originally Posted by Big_T View Post
    I am not sponsored. I have not been to any car show but there is this thing in auction the first fri of each month I'm going to try to make it to. Currently I have some major things in the works; my tail lights are in the post, I dropped my maz6 camber arm off to be extended (sleeved and tapped) and once Rodrigo from Font Motorsports confirms that the K-Sport coilover does indeed come with a camber plate, I will place my order.
  5. #50
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,666
    Mazstyle as well, has a lot of mods.
  6. #51
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Quick updates as I haven't been updating. A few days ago got into a fender bender, it's being fixed Monday.
  7. #52
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Got my Crystal Eye LED's. Was going to wait to install them but I wanted them on now. I'm debating if I want to dip the bottom reflector, or I may just put some tint over it, which I got cheap on ebay. The lights have been wired into the third brake light, otherwise they won't brighten when you touch the brake. Very simple to install, the brake line was just an issue of wiring tapping, not much unlike installing dual horns (pre 2016). Only tools needed are a 10mm socket and a flathead for prying. Also at the same time the Whiteline sway bar brackets came, and the camber gauge now I'm just waiting on the coilovers to come in the mail.
  8. #53
    Registered Member jomar23CX5's Avatar
    Mazda CX5 6spd Sport
    Join Date
    Jan 2014
    Location
    Sin City
    Posts
    159
    It looks really good man, it flows well
  9. #54
    Registered Member mazdaspeedmyk's Avatar
    2010 Mazdaspeed3 - Celestial Blue Mica
    Join Date
    Oct 2010
    Location
    Los Angeles, CA
    Posts
    113
    Those look great. I'm surprise they weren't plug and play. Did they come with alligator clips for splicing into the brake line, or did you have to cut and wider them?
    2015 Mazda CX5, Touring - Soul Red Metallic
  10. #55
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Well, all parts aside from the brake light intensity increase was plug and play. The directions showed wire taps, so I used some I had left over from my horns. On that note, evwn the oem hitch harness is tapped, while the aftermarket is plug n play lol. Once I get the damage next week repaired ill be reinstalling my hitch wiring. * clips were not included.
  11. #56
    Join Date
    May 2013
    Location
    Posts
    2,666
    Sorry to hear, about your fender bender. I had one myself, a couple of months ago, similar to your at the front.
    It blends nicely with your theme, but I don't think that it would look good, with other colors.
  12. #57
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Quote Originally Posted by tibimakai View Post
    Yea, I think it would look bad on a non black or white car, but they have other light colors as well.
  13. #58
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Just noticed I never posted my sway bar video
  14. #59
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Crystal Eye Taillights installed.. stay tuned for next mod it's pretty big..
  15. #60
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Quote Originally Posted by kimchei6
    Hey I was wondering where you got the aftermarket LED tail lights.. I saw few on eBay... How was the installation? Plug and play or does it require soldering and cutting? Thanks for the help.. I was thinking of getting a set..
    I got mine at Japanparts.com. Installation was plug and play except for the 3rd brake light functionality. You have to tap into the 3rd brake wire (wire tap or solder if you want) to have your tails get brighter when the brake is pushed. The ebay one most likely is from the same manufacturer but they don't offer all of the styles sold under "crystal eye". They also have a red side reflector instead of color matched. They appear to use the same connections.
Similar Threads
  1. Chris_Top_Her CX-5 Build Thread
    By Chris_Top_Her in forum CX-5 Lounge
    Last Post: 08-15-2017, 07:55 PM
  2. Another build thread...OMG!!
    By FunkyBuddha in forum Mazdaspeed Protege
    Last Post: 12-18-2014, 02:23 PM
  3. Aw_MP5 - Build Thread - Slow Build
    By Aw_MP5 in forum Protege5 Builds
    Last Post: 05-13-2014, 12:45 AM
  4. T.m.t.g.m.s build thread
    By repthemazdas in forum Mazda Protege
    Last Post: 01-26-2014, 01:22 AM
  5. My Build Build Thread
    By Boosted_Speed in forum Mazdaspeed Protege
    Last Post: 05-26-2013, 11:45 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
