Page 3 of 12 FirstFirst 12345 ... LastLast
Results 31 to 45 of 178
Thread: Chris_Top_Her Build Thread 2
  1. #31
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,088
    wasn't really a hassle, however 3 weeks later they just now seem to be getting around to transferring my plate, which I need ot pay $200 for since it's vanity. But it took them 3 weeks to get to it lol. and I'm supposed to get a pass to the harris hill raceway.. no one seems to know the details yet I know of another owner who bought his car and got his pass
  2. #32
    I shock donuts! subspeed6's Avatar
    2016.5 CX-5 Grand Touring
    Join Date
    May 2007
    Location
    Drury Lane
    Posts
    5,238
    Edit: I can't read.
  3. #33
    Registered Member mazstyle's Avatar
    CX-5, 2.2 Diesel, 2013
    Join Date
    Nov 2013
    Location
    Auckland, New Zealand
    Posts
    171
    ??Working camber arm??, I showed you guys what to do and it works perfectly for me, I did hope you of all members would have run with that simple mod.
  4. #34
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,088
    Installed my Auto EXE links today (Correctly I hope). Hopefully they hold up well with the CS sway bar and Hotchkiss brackets. I actually ended up making them slightly longer to use the stiffer setting, because when I had them short the angle was very acute and the bar was close to the axle.
    In Picture - White Ultra Racing Lower Front and Lower Rear arm bars, Dark Blue H&R Springs, Light Blue C/S Swaybar (stiffest, hopefully these $300 links don't break..), and red Auto EXE links. Hotckiss brackets not visible.
  5. #35
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,088
    Next item, going to grab the Mazda 6 adjustable camber arm and have it modified so I can use it.. I need to fix the camber before I buy new tires.
  6. #36
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,664
    Nice job Chris.
    I'm done with the audio on my car, except some minor tweaking.
    I will have to concentrate on the springs, camber and wheels.
    I will have to remove remove the camber arm and do some measurements. I'm thinking about plugging in the existing holes and drill new hole off center.
    I have to see the bushing, to see how much room is there to do this.
    If it's possible, I would do both ends. It won't be adjustable.
  7. #37
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,088
    Quote Originally Posted by tibimakai View Post
    Nice job Chris.
    Good luck. I just hope I can find a machine shop local that will not charge an arm and leg to extend the bushing out.
  8. #38
    Join Date
    Nov 2013
    Location
    Posts
    171
    Any updates ? Need more peeps modding
  9. #39
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,088
    Quote Originally Posted by mazstyle View Post
    Yes im probably going to have the end link middle changed. Ocassional clink even on soft at full length. I think its partly b/c the cs bar is not was wide as stock. I probably should re-examine the bracket mount too, I may need to add a shim or something under it., or it may be loose.
  10. #40
    Join Date
    May 2013
    Location
    Posts
    2,664
    In the next couple of days, I will machine out the Audi wheels hub bores. Wheels are with me in the shop, I just need time.
  11. #41
    Registered Member
    2014 CX-5 / TVR T350
    Join Date
    Feb 2004
    Location
    Taiwan
    Posts
    39
    Quote Originally Posted by Chris_Top_Her View Post
    Hella's and 6k Hids installed
    Did you require any additional relays/wiring for the hellas or was what came in the kit sufficient?
  12. #42
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,088
    Had a new middle rod fabbed for my auto exe endlinks. these are slightly longer I can now run max stiff with no binding.
  13. #43
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,088
    compared the mazda 6 camber arms I bought to the OEM arm (at the dealership) today. Figure I need at least 30mm of extra length.
  14. #44
    Registered Member dragonteeth's Avatar
    '15 CX-5 Touring AWD w/ Bose ★
    Join Date
    Jul 2014
    Location
    Seattle, Washington
    Posts
    207
    mazda 6 camber arms - to be extended ~ 30mm
    Where'd you buy these? They look great.
  15. #45
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,088
    Quote Originally Posted by dragonteeth View Post
    Buy what? you relinked the entire post.. If you could edit it and delete some of the picture URL's.. if you are talking about the horns, I got them from a local 4x4 store, but you get get them on amazon, hella supertones.
Similar Threads
  1. Chris_Top_Her CX-5 Build Thread
    By Chris_Top_Her in forum CX-5 Lounge
    Last Post: 08-15-2017, 07:55 PM
  2. Another build thread...OMG!!
    By FunkyBuddha in forum Mazdaspeed Protege
    Last Post: 12-18-2014, 02:23 PM
  3. Aw_MP5 - Build Thread - Slow Build
    By Aw_MP5 in forum Protege5 Builds
    Last Post: 05-13-2014, 12:45 AM
  4. T.m.t.g.m.s build thread
    By repthemazdas in forum Mazda Protege
    Last Post: 01-26-2014, 01:22 AM
  5. My Build Build Thread
    By Boosted_Speed in forum Mazdaspeed Protege
    Last Post: 05-26-2013, 11:45 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
