Page 12 of 12 FirstFirst ... 2101112
Results 166 to 178 of 178
Thread: Chris_Top_Her Build Thread 2
  1. #166
    Banned Chris_Top_Her's Avatar
    Donated: $45
    CX Moderator
    '15 CX-5 Miata GT AWD w/Tech 2.5L
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Something new coming straight from Japan... Stay tuned
  2. #167
    Registered Member J.Mike.CX5's Avatar
    '13 CX-5 Grand Touring w/ Tech Package, 2.0L FWD
    Join Date
    Aug 2012
    Location
    Lubbock, TX
    Posts
    37
    Quote Originally Posted by Chris_Top_Her View Post
    Got my Crystal Eye LED's. Was going to wait to install them but I wanted them on now. I'm debating if I want to dip the bottom reflector, or I may just put some tint over it, which I got cheap on ebay. The lights have been wired into the third brake light, otherwise they won't brighten when you touch the brake. Very simple to install, the brake line was just an issue of wiring tapping, not much unlike installing dual horns (pre 2016). Only tools needed are a 10mm socket and a flathead for prying. Also at the same time the Whiteline sway bar brackets came, and the camber gauge now I'm just waiting on the coilovers to come in the mail.
    Hey man, love what you've done with CX-5. I got similar taillights off E-bay for a great deal, but the connection for the reverse lights was not long enough to reach, so I had to return it. Where did you get yours from and does it pass Texas Inspection with no problems? Was always told that the rear lights have to have a red reflector? Thanks in advance.
    2013 Mazda CX-5 Grand Touring FWD, Crystal White Pearl Mica
  3. #168
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Quote Originally Posted by J.Mike.CX5 View Post
    Those were ordered from Japan.. but I ended up replacing them with a Taiwan knockoff when I messed one of the lenses up. Red on the side. Never had an issue with inspection
  4. #169
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Installed Corksport poly trans mount. Entirety from a performance interest, but turns out the oem was starting to rip.
    Did not notice any increase in vibration over what I already have.
    Turn in grip is better with less weight shift, and acceleration particular at WOT or wot shift feels more planted.
  5. #170
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Installed Ultra Racing 4 Point rear lower arm bar. Long time coming, had been running the 2 point rear bar since about 2014. But the AWD 4 point bar to compliment it came out in late 2017/2018
  6. #171
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    Installed New rear LED taillights from Japans. They have sequential (selectable) blinker.
    I almost blew up one of the modules. Like most aftermarket LED lights, they use an extra power wire to trigger the extra bright when applying the brake. I tried to use my old wiring from the last set, which was tapped into the third brake light. They used an identical connector clip. Well the power was not enough or something, and while testing, I accidentally connected the power wire (the wires are female on both sides, and identical) main brake light into the power wire leading from the 3rd brake light "+power---><----+power" while I had on a brick on the brake to see if it would light. Smelled burning and no more brake light increase on the right side :s. Hours later I realized the lead inside the connector had got hot enough to melt into (very lucky at first I thought it popped) the plastic.. cleaned it off and out and back in business. Last thing I want after $500 spent. the black lead on the right was the covered in melted plastic preventing contact. These lights use power from the main brake light directly to the inside taillight, which I had to fish a wire into the hatch (which I was trying to avoid being lazy).
  7. #172
    Registered Member CX-5um's Avatar
    13' CX-5 and 16' Mazda6 both Touring w/Tech/Bose
    Join Date
    Jul 2012
    Location
    Glendale, AZ
    Posts
    3,010
    Man those look proper. The housing looks like it sort of sticks out further too.
  8. #173
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,731
    I really dig the sequential turn signal.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 81k miles
    01/2013 build | 4/20/2013 delivery
  9. #174
    Registered Member tibimakai's Avatar
    2014 Mazda CX-5 Touring
    Join Date
    May 2013
    Location
    Los Angeles-San Dimas, USA
    Posts
    2,666
    I had an idea long time ago, which I think it is a good one, to have sequential brake lights as well. More pressure you apply to the pedal, more Leds would turn on. The min and max limits Leds would be on all the time.
  10. #175
    Registered Member
    16.5 CX-5 GT AWD w/Tech BRMica
    Join Date
    Oct 2015
    Location
    Dirty South
    Posts
    2,047
    Quote Originally Posted by ColoradoDriver View Post
    Me too!
    Quote Originally Posted by tibimakai View Post
    Thought this for awhile now too. Great idea!
  11. #176
    Donated: $5
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,731
    Care to share a link to said product?
  12. #177
    Registered Member Anchorman's Avatar
    2019 CX-5 GT 184 2.2 diesel auto - Sonic Silver
    Join Date
    Jan 2016
    Location
    Derbyshire UK
    Posts
    2,417
    The new CX30 has LED flashers. I*m confident they will appear on the next CX5 revision. Whether they will be the travelling ones is a different story.
  13. #178
    Donated: $45
    CX Moderator
    Join Date
    Sep 2012
    Location
    San Antonio TX
    Posts
    6,090
    https://global.rakuten.com/en/store/...m/ltl-mz02-sp/
    They have a knockoff on Ebay for cheaper but they only come in like two colors. The wiring is different based on your cx5 year(manufactuer year, not US +1 MY) as well.
    They are on sale and yen is weaker than USD right now.
Similar Threads
  1. Chris_Top_Her CX-5 Build Thread
    By Chris_Top_Her in forum CX-5 Lounge
    Last Post: 08-15-2017, 07:55 PM
  2. Another build thread...OMG!!
    By FunkyBuddha in forum Mazdaspeed Protege
    Last Post: 12-18-2014, 02:23 PM
  3. Aw_MP5 - Build Thread - Slow Build
    By Aw_MP5 in forum Protege5 Builds
    Last Post: 05-13-2014, 12:45 AM
  4. T.m.t.g.m.s build thread
    By repthemazdas in forum Mazda Protege
    Last Post: 01-26-2014, 01:22 AM
  5. My Build Build Thread
    By Boosted_Speed in forum Mazdaspeed Protege
    Last Post: 05-26-2013, 11:45 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
