Page 16 of 19 FirstFirst ... 61415161718 ... LastLast
Results 226 to 240 of 272
Thread: High Mileage CX-5s - report in
  1. #226
    Registered Member yrwei52's Avatar
    Donated: $8
    2016 Mazda CX-5 GT AWD w/Tech
    Join Date
    Mar 2015
    Location
    Plano, Texas, USA
    Posts
    7,703
    Arrow High Mileage CX-5s - report in
    Quote Originally Posted by PatrickGSR94 View Post
    Dang we have 88K on our 2014 and I still haven't changed trans fluid. Need to get on that...
    I'd do it ASAP in your situation at 88K miles as I simply don't believe there's a lifetime ATF exists. I may do 2 ~ 3 drain-and-fills, and replace the filter cartridge at the last drain-and-fill.
    Transmission TSBs are for early CX-5's and it's manufacture's poor design on front casing. Since then Mazda had modified the front casing, you have to find the TSB which may have info on when Mazda did the change. Of course our TSB thread has lost all the URL links been forced by Mazda, and it's essentially useless now.
  2. #227
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,418
    Called it at 106K on mine. Fuel system problem got it. Never changed ATF, never had shifting issues.
  3. #228
    Registered Member
    2014 CX-5 Grand Touring AWD, Liquid Silver
    Join Date
    Apr 2013
    Location
    NJ
    Posts
    817
    84,000 miles on our 2014 now. Transmission is fine, but having electrical issues. Latest is the lift gate is stuck closed. Bought the parts and will change the actuator today. I just realized there is an additional lock switch on the tailgate so I bought that in case its not the lock actuator.
  4. #229
    i-ACTIV AWD Aficionado Kedis82ZE8's Avatar
    Donated: $25
    '15 CX-5 GT AWD w/tech
    Join Date
    Jul 2014
    Location
    WA State
    Posts
    4,796
    Blog Entries
    6
    Quote Originally Posted by Heritage07 View Post
    Yeah...that lock button is easy to forget about under there.
    '15 CX-5 GT 2.5L w/tech package - 50K Miles - https://www.oemvehicleparts.com/ (30% off "shipping" with code "MAZDAS247")
  5. #230
    Registered Member
    Join Date
    Apr 2013
    Location
    NJ
    Posts
    817
    Update, switch on lift gate is fried with a pin that is stuck in the harness. I ordered a new switch, but I am concerned with the connector on the harness since the switch pin broke off. I changed the actuator anyway and put everything back together. Now if I may need to find a new harness clip.
  6. #231
    Registered Member
    2016 Mazda, CX-5 GT
    Join Date
    Dec 2013
    Location
    Magnolia TX
    Posts
    84
    106K on my 2016 GT. No issues ever. I have replaced the brake pads at 75K . The spark plug around the same. Did a drain and fill on the transmission at 50 and 75K. Finally, on my third set of second set of replacement tires. Has been a great car.
  7. #232
    Registered Member
    Join Date
    Mar 2019
    Posts
    3
    Should I buy? 2016 CX 5 Sport 92k miles.
    I think this post belongs here.
    I'm going to look at a 2016 CX-5 Sport AWD w 2.5 L in a couple days. It has about 92k miles on it.
    One owner personal vehicle. Has been in to Mazda dealer every 4-6k miles for "regular maintainence" per Carfax.
    Looking at this car for my 16 yo twins.
    What concerns should I have in view of the mileage?
    Thanks- this is my first forum post.
    Jon D
  8. #233
    Registered Member
    2013 Mazda CX-5 Sport FWD Auto
    Join Date
    Oct 2012
    Location
    FL
    Posts
    252
    May need new spark plugs if those were never done. Coming up on the coolant change requirement (120k on the 2.5L?). You could drain and fill the transmission fluid, up to you if you agree with the lifetime spec or prefer to replace for peace of mind. AWD: see when the differential fluid was last serviced. Last thing to check would be accessory belt if thatís never been changed and the appearance of the water pump. Brake fluid flush would be great if thatís never been done too.
    Thatís all I can think of in the future for my 2013 (except for spark plugs, I changed mine at about 60k ahead of schedule). Very little maintenance required for these cars, mine is 2WD so even less to worry about). My Odyssey on the other hand..., lol.
  9. #234
    Registered Member
    CX5 GT-R
    Join Date
    May 2015
    Location
    South-Central US
    Posts
    7,418
    Quote Originally Posted by ruthrj View Post
    May need new spark plugs if those were never done. Coming up on the coolant change requirement (120k on the 2.5L?). You could drain and fill the transmission fluid, up to you if you agree with the lifetime spec or prefer to replace for peace of mind. AWD: see when the differential fluid was last serviced. Last thing to check would be accessory belt if that*s never been changed and the appearance of the water pump. Brake fluid flush would be great if that*s never been done too.
    That*s all I can think of in the future for my 2013 (except for spark plugs, I changed mine at about 60k ahead of schedule). Very little maintenance required for these cars, mine is 2WD so even less to worry about). My Odyssey on the other hand..., lol.
    Agreed. My plugs were just fine at nearly 80K miles, btw. My brake fluid had 3% moisture at around 97K. AWD diff fluid, I ended up getting a new diff at around 34K miles or so due to fording a stream. I never bothered to change it after that and it was fine. I had it checked around 80-90K miles or so and they said the fluid looked new and didn't recommend service.
  10. #235
    Registered Member
    CX5 Sport MT
    Join Date
    Jun 2012
    Location
    Seacoast NH
    Posts
    188
    I'm at 152k on my '13. Accumulating the parts to do a stage "0" refresh soon. Basically replacing a bunch of worn parts so I'm not chasing parts as they need replacing.
    Engine:
    Accessory Belt, Tensioner, Water Pump belt
    Coolant
    Spark Plugs (2nd time)
    Transmission oil (fwd, MT)
    Suspension: Control arms (I tend to drive fast and on rough roads)
    Springs and shocks are ok but may be up dated in summer. Tie rods are ok but may get replaced as well over the summer.
    Brakes: Pads/Rotors/Slide pins. Rear brakes have been my issue with this car, uneven wear, seizing caliper pins
    New fluid
    Original battery replaced this winter. Independent Mechanic did the control arms, fluids. I'll do brakes, belts, plugs, filters
    I haven't touched the intake or fuel system yet.
    No interior rattles or significant wear to fabrics. I haven't replaced a single light bulb which really surprises me. 8 years on original headlights.
    At this point I'll drive into the ground. Daughter may inherit it since she gets a license next month and has been doing well with the clutch. A couple of rust stains on the doors but I haven't found any bubbling (knocks on wood). I do wonder what it looks like under the wheel well plastic.
  11. #236
    Registered Member
    2017 Mazda CX-9 GT, 2015 Mazda CX-5 GS/Touring
    Join Date
    Nov 2011
    Location
    Windsor, ON
    Posts
    175
    I have just over 156,000mi/250,000km on my 2015 CX-5. No issues, but I did replace the battery last year because it was on its way out. Vehicle is oil sprayed every year since I live in the rust belt.
    Otherwise, Iíve done normal maintenance (oil changes, coolant flush at 125k miles, tranny flush every 60k miles) spark plugs, brakes and tires. I have front end links and new sway bar bushings that I will install shortly as the sway bar makes some clunking noises occasionally.
  12. #237
    Registered Member
    Cx5
    Join Date
    Jan 2019
    Location
    Vermont
    Posts
    81
    Quote Originally Posted by JOE MAMA View Post
    Have you had the vehicle since new? Have he transmission fluid changes just been draining the pan and refilling?
  13. #238
    Registered Member
    17 CX-5 GT
    Join Date
    Aug 2018
    Location
    Chicago
    Posts
    5
    Nice to hear old CX-5s are clocking miles well. Anyone with a 2017+ with more than 50k miles? So far so good over here.
  14. #239
    Registered Member
    Join Date
    Nov 2011
    Location
    Windsor, ON
    Posts
    175
    Quote Originally Posted by 2001birdowner View Post
    I have owned the vehicle since new and have been meticulous with maintenance.
    Flushes for both transmission fluid and coolant. Always serviced at the dealership. For the price of the fluids, I canít be bothered just doing a drain a fill. Itís easier and better to get a flush done so you know the fluid has been 100% exchanged. Itís expensive, but given the price tag of a new engine or transmission, I believe it to be cheap insurance.
  15. #240
    Resident barbarian ColoradoDriver's Avatar
    Donated: $5
    2014 CX-5 Touring AWD
    Join Date
    Apr 2013
    Location
    Denver, Colo-fornia
    Posts
    4,828
    I hope you know that the SkyActiv transmission does not have the external lines to do a flush unless they are modded on.
    You should see how much fluid you were charged on your invoices. If it was around 4 qts, it was definitely a drain and fill.
    2014 CX-5 Touring AWD 2.5L | Jet Black Mica - 82k miles
    01/2013 build | 4/20/2013 delivery
Similar Threads
  1. castrol high mileage=crappy mileage
    By Safe Zone Msp in forum Mazdaspeed Protege
    Last Post: 04-26-2010, 08:18 PM
  2. Mileage report
    By erhayes in forum Mazda CX-7
    Last Post: 11-19-2008, 05:06 PM
  3. On my way to Disney...Mileage report!
    By gpzjack in forum Mazda5 Lounge
    Last Post: 11-06-2008, 07:31 PM
  4. MSP6 Mileage report, 1st long trip
    By Mgkdrgn in forum Mazda6 Engine & Transmission
    Last Post: 09-07-2006, 01:09 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
